https://linustechtips.com/topic/475718-best-case-under-80-cad/#findComment-6374886
so i need a good first build case thats NOT the spec 01. it needs to have filters, usb 3.0 and decent cable management. I don't really care about the looks, as long as someone doesn't mistake it for a dell. Any suggestions?
What size does it need to be?
The NZXT S340 is 3 dollars overbudget but it's pretty good on NCIX.
Also the Sugo SG13 is under that price point and it's awesome, but I assume you're probably not doing an ITX build.
Sig under construction.
https://linustechtips.com/topic/475718-best-case-under-80-cad/#findComment-6374889
Cooler master silencio series, whatever fits your budget? They are good, have filters, and are really quiet.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/475718-best-case-under-80-cad/#findComment-6374894
it needs to fit an atx mobo and a 380.
The S340 looks like a pretty good option then.
The 100R Silent Edition is also a good bet but 5 over.
http://www.ncix.com/detail/corsair-carbide-series-100r-silent-83-104949.htm
https://linustechtips.com/topic/475718-best-case-under-80-cad/#findComment-6374915
Corsair 200R
NZXT S340
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/475718-best-case-under-80-cad/#findComment-6374941
