Posted October 28, 2015 Hi, So basiclly I finally decided to join the PC master race. I have about 750 to 1000$ CAD (600 to 800US) to use to buy a decent gaming pc that will last for at least a few years. Before I go buy the parts I would like you guys to help me build my PC. I will mostly play games on it (GTA V with mods, Black ops 3, minecraft, Heros of the storm,...) and do some office work (internet browsing, youtube and office 365). I was wondering : should I get my parts online (if so where?) or at some computer parts seller (any one knows a good one in Canada?)? What do you guys think of this build (I went to Computer Canada, where they suggested a computer) : Case 1 TBAMD (X8 FX-8320E) 3.2 GHZGIGABYTE (GA-970A-D3P / rev. 1.0) Corsair (CS / CS650M)G.SKILL (Ripjaws X)nVidia Strix GeForce GTX 970 4 GB GDDR5 (1 114 MHz, Memory 7 010 MHz, DVI double, HDMI, DisplayPort)Total : 1 169$ CAN or 879 US Currently have : Montion : 22 inch. 1920 x 1080 IPS (should I buy a new one?) I have windows 7 OS (should i buy a new one?) If I can get it for less than my budget perfect. I really have no idea if it's a overkill. I need your help. Thanks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 I will make you a pcpartpicker. Do you need other peripherals? Your Windows 7 is fine. Also, 1k CAD isn't 1300USD. Pick one. i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Author I will make you a pcpartpicker. Do you need other peripherals? Your Windows 7 is fine. Also, 1k CAD isn't 1300USD. Pick one. I am sorry, mymistake I changed that I could use a keyboard and mouse! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Computer Canada is wrong about suggesting the FX platform. It outdated and will not last a few years you will be better with the Intel Haswell or Skylake builds check the other tread for suggested builds http://linustechtips.com/main/topic/474926-build-me-a-gaming-computer-d/ Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible. Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Change your CPU to I5 and CHANGE YOUR PSU to EVGA/XFX etc (http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/) Magical Pineapples
