Posted October 27, 2015 Looking to get some better fans for my Kraken x61. Performance wise they are fine, but they tend to be a bit loud at higher speeds. Right now I have the Fractal HP-14 PWM fans on the way, but I figured I would see what you guys suggested. I am getting be quiet! Silent Wings 2 for my case fans but I don't know how well they would work as radiator fans as the SP is poor. I prefer not to use Noctua because I hate the brown color. | Intel i5-6600K | NZXT Kraken X61 | MSI GTX 980TI | NZXT Kraken X41 | ASUS MAXIMUS VIII Hero | Corsair Vengeance DDR4-3000 16GB | |Samsung 850 EVO 250GB | WD Blue 1TB | EVGA SuperNova G2 850W | Fractal Design Define S | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 27, 2015 w0t about the LTT's edition noctua fans FPS <3 Flick G1 Review Nixeus Revel Review Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 27, 2015 SW2's don't have a lot of SP but they're still pretty good. They're fine for rads if you don't mind sacrificing a few degrees for much lower noise. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
