2 way SLI GTX 770 or 1 390 and wait
AlTech
Hi all,
I'm looking to upgrade my graphics card setup sometime soon and I want to know if i should go for a second GTX 770 considering I have one already, or a new R9 390 and wait until i have enough money to buy a second.
To be clear  the  770 is a 2GB 770 not a 4Gb one.
Thanks.
EDIT: IF anyone has better ideas, I'm listening
Objective: Be able to play games on 1080p or 1440p at ultra (something I can't do now). And be able to drive a second or third monitor down the line
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
Sell the 770 and get a 390. Before you buy the second one make sure to upgrade your monitor.
Really?
Aya! I only just had this monitor for 1.5 years.
I want three monitors though. And three 1440p monitors seem quite expensive. (If you could find some cheap but good 1440p monitors that would be awesome!)
Really?
What kind of price range are you looking at? 1440P is getting cheaper.
144Hz, Gsnyc would be nice but its not necessary, IPS, Not sure on price but i thought they were around $300 USD each.
Get the R9 390 because the VRAM thing 2gb isnt enough...
EDIT:
And direct X 12
Oh, yeah, with 144hz Free-Sync monitors you're looking at more than that. If you want standard 60hz IPS 1440p monitors though they're a LOT cheaper than they were.
Wouldn't preformance also be a thing though since the 770 is nowhere near capable enough for Ultra much less 144Hz
I could do 1 1440p Free snyc 144Hz and then the rest could be 60Hz without free sync. How much would that be? Any specific monitors your reccomend?
I've been looking at the ASUS MG279Q (IPS) or the MG278Q (TN) even with my Nvidia card. Take a look at them.
Holy CRAP! It's $580 USD! WHAT! I don't have the money for this :( !  Looks like I'll be finding a cheaper option or just a 1080p option!
This is way too expensive for me!
144hz and Freesync is expensive :P if you want 1080P 144hz I personally suggest the VG248QE.
Um I'll take a look at that. I know that's not too expensive.
2GB vram is not really enough for high end gaming anymore, get a 390.
RIP in pepperonis m8s
Yeah I'm running out of VRAM in GTA V. And i was not getting good performance while playing GTA V at high settings (barely hitting 60 in some cases but hitting 70 in most). That's what prompted me to start looking for a new graphics card.
2GB for SLI is laugable. R9 390 is better.
Really?
get a ultrawide 3440x1440 monitor. It is AMAZING for gaming
also, if you can, get a 390X...
AHHHHH! All of you will be the end of me. You and my bank! I don't need that. I want 3 monitors, i currently have a 1080p monitor 60Hz but then I may get a 144Hz 1080p (1440p 144Hz is too expensive) and then another 1080p 60Hz.
what is your budget?
and how much do you think you would get/have in total if you sold both your 770 and existing 1080p monitor?
I don't a whole ton of money know but I will save up and get enough for 2 more monitors and 1 more graphics card (plus wait a while longer) then buy another of said graphics card.
Budget = IDK i'm saving up money and then actually go buy the damn thing! OK?
I know I'll be able to spend about $130 USD for the 1080p60Hz monitor, $269 for 1080p144Hz monitor, $329 per R9 390 ($329 x 2) .
You'll have to forgive me, maths was never my strong point and on top of that I'm converting to USD which is a little annoying.
EDIT: Oh and I will sell the 770 but i don't know how much that will fetch
@AluminiumTech
so say you have a total of 1000 USD + say 150 USD for the 770 and 50 bucks for your exsting 1080p monitor ok?
that puts us at around 1200 USD
that means we can get this:
http://pcpartpicker.com/part/aoc-monitor-u3477pqu
and this:
http://pcpartpicker.com/part/msi-video-card-r9390xgaming8gle
Grand total: 1103 USD
