Looks bent or a little out..
Not sure though, What do you guys think?
1 : post-68968-0-59375100-1445556443_thumb.j
2 : post-68968-0-49736100-1445556473_thumb.j
3 : post-68968-0-48093800-1445556500_thumb.j
4 : post-68968-0-52937900-1445556529_thumb.j
Intel Core I7 7820X | Asus Rampage VI | Gigabyte RX 580 XTR | 32GB Crucial Ballistix | NZXT Kraken X62
ADATA XPG 256GB PCIe| Cosmos C700P CM | Lepa MaxPlatinum 1050W
https://linustechtips.com/topic/471859-should-i-be-concerned-cpu-socket-pin/
You can probably re-adjust it, but it goes without saying that you should be very, very careful. CPU socket pins are extremely delicate, and if you snap one off, you're in for a world of trouble, which could mean possibly replacing the motherboard.
In my opinion, I'm not certain if it's worth the risk to reseat it yourself, especially if it's an expensive motherboard. Consider going down to the outlet you purchased it from and informing them of the defect, as trying to fix it yourself might void the warranty on the board, forcing you to purchase another.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Carefully pull it back into its proper position with tweezers, and you're fine.
Looks like I fixed it because I can't tell anymore which one it was lol
1 : post-68968-0-95666100-1445558320.jpg
2 : post-68968-0-92030000-1445558338_thumb.j
3 : post-68968-0-54804600-1445558351_thumb.j
The credit card swipe trick is probably easier in this case.
Credit card swipe trick?
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
You swipe a credit card between the pins to line them up.
Lol. I didn't know that.
i straightened out an old p4 cpu i think it was, with totally wrecked pins (every one bent in different directions) and got them all straight in about 20min and it posted! Used a razor on its side thou, credit card would probably be better.
Glad you got yours straightened out
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
I'm not OP, buddy. :)
I'm not your buddy, fwiend. ;) haha it's hard to keep track of who is who on mobile.
Edit: different color profile pic and everything lol
I'm not your fwiend, pal.
