Hello all. I'm building a gaming pc, and its my first ever build. I was wondering if this build will hold up to 1080p/60fps on max settings with most modern games. I also need a recommendation for a PSU that can power this build, and I need to know whether it's important to have an aftermarket CPU or GPU cooler if I don't overclock either one. Thanks, LTT!
https://linustechtips.com/topic/471066-build-help/
Any budget? And if you don't overclock, you should be fine with the stock CPU cooler. Unless you get annoyed with how much sound it makes (not that much), then you can swap out for an aftermarket CPU cooler. I would recommend a PSU from EVGA (*My opinion*). Just letting you know, Corsair CX PSUs dont get much love on this forum...
~~ Intel Xeon E5-2696 v4, Asus X99-A II, Adata 2x8 GB, EVGA GTX 980Ti FTW, InWin 303, Dell U3415W~~
https://linustechtips.com/topic/471066-build-help/#findComment-6316334
The only thing would to use a H97 chipset motherboard, because you can't overclock your CPU because it isn't a "k" part, like the 4690k. Also, you do not need aftermarket cooling, especially since you are using a non-overclocking CPU. The graphics card already has aftermarket cooling, MSI's cooling.
H97 motherboard - this is the exact same product line as your current one, but it uses H97 rather than Z97 and as a result it should be cheaper.
http://us.msi.com/product/mb/H97-PC-Mate.html
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
https://linustechtips.com/topic/471066-build-help/#findComment-6316346
My budget for the PSU is around $50USD/$65CAD, but I can go higher if it means a more reliable PSU. Also, thanks for the cooling info. I think I'll stick with the stock cooler, because noise isn't an issue.
https://linustechtips.com/topic/471066-build-help/#findComment-6316369
OK, thanks! To clarify, that MOBO is the same, but without overclocking support? Also, do you know how much it would cost me to step up to multi GPU support on the MOBO?
https://linustechtips.com/topic/471066-build-help/#findComment-6316379
Antec High Current Gamer 620M - get that.
https://linustechtips.com/topic/471066-build-help/#findComment-6316418
Its not great tbh intact it's effectively useless without a psu
https://linustechtips.com/topic/471066-build-help/#findComment-6316443
Given the psu budget quote in US & CA $, I take it the purchase is being made in Canada.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($227.03 @ Vuugo)
Motherboard: Asus H97-PLUS ATX LGA1150 Motherboard  ($129.75 @ Vuugo)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($57.98 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($58.03 @ Vuugo)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($428.98 @ Newegg Canada)
Case: Corsair 100R ATX Mid Tower Case  ($65.50 @ Vuugo)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($119.99 @ NCIX)
Total: $1087.26
Generated by PCPartPicker 2015-10-21 14:32 EDT-0400
https://linustechtips.com/topic/471066-build-help/#findComment-6317453
What is?
you didn't include a psu in your link making it useless
https://linustechtips.com/topic/471066-build-help/#findComment-6317636
Yes. Also, the motherboard supports AMD Crossfire, but not Nvidia SLI. Also, If you are planning to do a 390 Crossfire, you will need a 1000 watt power supply or higher.
https://linustechtips.com/topic/471066-build-help/#findComment-6319931
