I'm on the fence of what to do, Create a custom loop or just buy a AIO. I have a Case-Labs S8s with support up to two 240/280 on the top, two 140 at the bottom and front. Plus four 120 Support one side, one infront and back(x2).
1. What kind of temps should I except when using a custom loop? I have a 5960x at default settings currently, will add EK GPU block for MSI 980 Ti.
2. Is it worth getting into water cooling or should I just grab EK Predator 240 and be done with it?
3. How often do you need to drain and refill the loop?
4. Is Killcoil the only thing needed?
5. What best radiator to use? I want something that requires low RPM. Going for quiet and low temps.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/466726-aio-or-custom-loop-need-help-deciding/
go aio unless your willing on spending at least $ 300 for cpu only, $550 for both
1. lower depends on how many rads. but they will drop alot, especially load
2. its our own to think abou it
3. 6 months to a year
4. no, something like a metal cohesive (not sure what called, but to stop metals from getting in the loop)
5. EK thick rads are very good
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
wait why are you spending so much money on a cpu?!!
"God created war so that Americans would learn geography"
because thats how much custom watercooling costs...
1. Depends how many rads you put in it, the more the better.
2. With a Case-Labs case I'd say it'd be a shame to not do a custom loop in it. But you don't really do it for practicality (or purchase a case-labs case for that matter)
3. Ideally every 6 months to a year.
4. A specialized coolant would be better, they come with everything you could possibly ever need.
5. Any really, just bear in mind the raw thickness of a radiator makes very little difference.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Id get a predator 360 and if I rrc you can hook it up to your gpu also
My case doesn't have the room for 360, My case is a bit smaller, It just fits the 240 AIO. You can hook up 240 to your GPU too, 360 version is just easier to do that.
cpu loops cost quite a bit for a good pump rad and fans alone
Rigs I've Built
because he needs a rad,pump,res,tubing,blocks,fittings, the only difference between a gpu+cpu and a cpu loop is the gpu block, thats why if your going custom its better to do it for your cpu and gpu not just your cpu
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
not at all a cpu block is 100$ you can make a loop for 300$
yeah thats what he said...
$300 for a CPU only watercooling loop
ya thats what he said
edit: ninja`d
edit 2: also you can get a good cpu block for less than 100$ :/  ek supremacy mx is 70-80$
and a car thread !
