I dont know whether im installing my cpu cooler wrong because my motherboard has a bit of flex in it. i have a picture to show how flexed it is, can someone tell me if this is normal or i screwed up?post-258872-0-70293600-1444105761_thumb.
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
https://linustechtips.com/topic/462280-motherboard-flex/
it normal with heavy coolers
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/462280-motherboard-flex/#findComment-6203931
normal
it wont break
https://linustechtips.com/topic/462280-motherboard-flex/#findComment-6203982
I'd probably bend that much if you put that cooler on me too!!  jk   It's pretty normal and should even out a bit even just by installing the mobo in a case.  When I was aircooling with large coolers I kept my mobo oriented horizontally to keep it from pulling down/away from the motherboard but I'm pretty sure that's just me being asinine since TONS of people use them and very few have problems.  As long as you aren't throwing your pc around you should be just fine
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/462280-motherboard-flex/#findComment-6204062
