Would running two MSI GeForce 4GB 256-Bit GDDR5 on this system build be advisable? The motherboard is SLI compatible, I have the power and it could fit in the case.
What could be the benefits of running two vs one? I'd like to use two so that it doesn't stress one out and they support great graphics. I plan on hooking up this system to not only a monitor (4K) but also a 55 inch TV (4K).
First PC Build: NZXT S340 Build | Click to view other accessories.
CPU:Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler
Motherboard: Asus MAXIMUS VIII RANGER ATX LGA1151 Motherboard
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive x2
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card
Case: NZXT S340 (White) ATX Mid Tower Case
Power Supply: SeaSonic X Series 850W 80+ Gold Certified Fully-Modular ATX Power Supply
https://linustechtips.com/topic/461598-running-two-gpus/
If you're running 4K two 970s will be a lot smoother than one, but it would probably be better to buy one 980ti instead for the extra memory.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/461598-running-two-gpus/#findComment-6193969
Not all games support SLI, so there's that. You'll definitely need both for running at 4K with decent settings.
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
https://linustechtips.com/topic/461598-running-two-gpus/#findComment-6193977
check the price of a 980 ti. The performance of 2 970s, and a 980ti will be fairly similar, but you are guaranteed all of that performance on the 980 ti.
I had 2 760s and sli scaling was very good in most games, but it was just less elegant than the 780ti that I have right now.
You also get more vram with the 980 ti.
If you are set on the 970, it should work fine with your system. Most motherboards these days with multiple 8x/16x pci-e slots are sli certified...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/461598-running-two-gpus/#findComment-6194005
It's called a 980ti is a better choice.
According to the most recent jayztwocents kingpin review sli 970 oc'd compared to a 980ti oc'd the preformance of both at every resolution is fairly on par (with the sli 970 being a bit better at 1080p) (once memeory is overclocked a lot of vram limitations go away as seen in the extreme case of the fiji gpu lineup)
The biggest issues are then dealing with sli, but if you have one 970 already I would definitely recommend a second instead of going through the hassle of selling and buying a 980ti at the moment.
Also people never mention it but cpu bottlenecks show up more and more with sli builds over single gpu and I personally would never recommend doing sli with less than a I7 or a significantly overclocked I5.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/461598-running-two-gpus/#findComment-6194087
