My Current Power Supply
Solved by The Cool n00B,
So I bought this power a year ago due to a computer problem that actually led to be over heating, (Not a PSU issue)
I heard the G2 and GS were good power suppies, but what I got was this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438026
which happens to be a G1.
Was this a good buy or is this a bad power supply? So far i have had no problems with it and if it did go out I do have the old power supply to get me going til i could replace it.
I have that exact PSU. I've had it for a year, I ran an overclock for a while. It's good, but the G2/GS is better for overclocking for some reason. You'll be fine.
