OUTLET EXTENSION SURGE PROTECTED
Solved by d3sl91,
Sup? I'm looking for suggestions of the best price per performance outlet extension that is surge protected.
I'll be hooking up 2 pc's, 2 monitors and a ps3
the computers use a 500 watt and 620 watt psu.
i use the US style outlet btw.
Just get whatever one you want from APC or Tripplite and they will be fine.
In reality, most will be fine, but if you want a name brand...there ya go.
