2 audio sources
Solved by Shinrin_Cole,
How do I get to the sound from the line in, or will it just start playing?
You may have to go into your sound settings and unmute it and turn it up to a desirable volume. if it's too low on your computer and you hooked up from the microphone port on the TV, you can turn up the TV volume to help. If you don't hear anything out of line in after this, you may have to go into your sound settings click recording, right click on the line in and tell it to listen to the audio and this should work. I'm at work and can't tell you the correct option name right now. But it should work with option #1 off the bat.
