Help Me with Amazon
dont you have a bank account? Buying things online with visa gift cards always causes problems.
Haha no. Of course I don't, I'm 16. I'm about to open a checking account though, since I have a job interview today and hopefully a job.
Last time I've tried a prepaid gift card on Amazon it didn't work so I used that to shop at retail stores where they accept it. Should have bought Amazon gift card, that way you can just add the amount to your account and it will deduct from your Amazon balance. The card are sold almost everywhere, minimum is like $25 dollars and goes up to $100 dollars. There are even ones that you can set your own amount and value starts out at $25 minimum, up to $500 maximum.
ebay has gift cards too
Well I didn't want to buy one or the other and not be able to use it if I found a better one on a different site. Plus I've used Amex cards before.
Check the balance of your pre paid; If the amount was removed, Amazon will send you the product, you just have to wait for the rep to email you back.
Next time, if the order does not go through the first time, do NOT try 4 times in a row; that's asking for trouble.
Anyone seeing that at amazon will assume you're trying to manipulate a system or something, and lock you out like they did.
Okay, can I get to my update now?
Update, I woke up this morning, went into my account, and the order is went through. The Amazon rep didn't contact me but just unlocked my account, as I explained that the card was a gift card in the email they told me to send. I will check Amex with the gift card balance to see if it charged.
Edit: Yep, card was charged the amount the phone cost. Thanks for the help guys, next time I will buy site specific cards.
