I know it's not out yet but what do you think the best case for it is?
you know any best iPhone 8 cases?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/451029-best-iphone-6s-plus-case/#findComment-6047580
Tech21
if the phone is not out? how do we know cases are out?
Same shape and size of the iPhone 6, all of its cases should work for the 6S.
https://linustechtips.com/topic/451029-best-iphone-6s-plus-case/#findComment-6047589
lol "s" more features
Otterbox is pretty popular in my location so \_(ツ)_/¯
i mean, the s has 2gb of ram....
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/451029-best-iphone-6s-plus-case/#findComment-6047639
zenfone has 4gb of ram.... for 1/3rd the price so....
lets end it here yea? don't want to create a flame war :)
mkay
https://linustechtips.com/topic/451029-best-iphone-6s-plus-case/#findComment-6047701
