Is there a motherboard size smaller than ITX?
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/450746-smaller-than-itx/
not really unless your talking custom or laptop boards
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043576
Thin ITX (shorter), Pico ITX (a full size down), and more that are NUC sized. What you need to know is that for normal desktop hardware, you will need a Mini ITX or higher.
Intel Core i7 4770k - 2x Geforce GTX 780 - MSI Z87 MPower Max - Corsair H60 - 8GB Avexir Core Series MPower Yellow + 4gb no-brand DDR3 - Corsair Obsidian 750d - AData XPG SX900 256gb SSD - Seagate Barracuda 3TB (7200 RPM) - Hitachi 250GB 2.5in HDD (3200 RPM) - WD HDD 160GB extracted from iMac via black magic (no specified RPM) - ASUS VG248QE 144HZ 3d Vision Monitor - Logitech G602 - Ducky Shine 3 TKL - AKG 172 HD Headphones - Xperia z2 - Sony Noise canceling earphones -  Nikon D5200 With Bundled Lenses - Windows 7 Home Premium - Blue Snowball iCE - Acer Aspire X with a broken case, AMD A6, and Raijintek Aidos CPU heatsink
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043599
Intel has a new 5x5 standard (which incidentally is not 5x5 in any measurement) that is used for tiny PCs with soldered-on CPUs. It's slightly smaller than ITX, but not enough to be worth it over ITX for consumers.
You can already fit a full ATX machine inside an enclosure the size of a large lunchbox if you do it right. ITX just makes it a bit smaller. If you're going for crazy tiny, you want an ASRock Beebox, Gigabyte Brix or an Intel NUC.
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043603
Intel has a new 5x5 standard (which incidentally is not 5x5 in any measurement) that is used for tiny PCs with soldered-on CPUs. It's slightly smaller than ITX, but not enough that ITX would be worth it.
what fucking john cena of a lunchbox are you using to fit a atx motherboard in in
basically you can get a good nuc or a msi AIO
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043630
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043642
Sometimes you just need to carry a whole turkey dinner to work.
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043645
LMAOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043646
Dont forget the Intel Compute Stick
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043652
IDK, this is my lunch box, 15L. Seems mighty small for an ATX build..
http://www.igloocoolers.com/Coolers/All-Coolers/Playmate-Elite-Ultra-Blue
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043663
oh, those kinds of lunch boxes. atx maybe not but matx and itx are probable
i was thinking this lunchbox
u_20260840_Half%20Moon%20Bay_Tin%20Totes
My Rig
Total: $2074.22
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043676
This one.
It's better than your Fucking John Cena. :P
I can fit all the sandwiches I desire in it.
:-O wow... this... sketchy. I know cardboard is perfectly fine but still, wow. Amazed people do this, lol.
ᕦ(ò_óˇ)ᕤ PROJECT: GreenLANTERN (click to view)
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043742
People want an antistatic home for their PC, what better than cardboard? :D It's totally fine, it works really well. Actually one of the cheapest PCs in its class. It can game just fine.
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043754
More power to you, lol. I couldn't do cardboard.
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043775
There used to be a couple standards smaller than ITX, but all of those died out in favor of the standard options.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/450746-smaller-than-itx/#findComment-6043810
