I understand this it a tech forum not a car forum but i know you guys are smart in many ways. So recently my car a 2007 nissan sentra s has been having problems and i want to know if you could help me!
1) When i start the car it starts and the rpm meter stays at 0 rpm for a second then it jumps to 1500 rpm and fluctuates a bit and then idles normally and drives
2) also when i drive and brake a little harder then let off the brakes then it feels like there still on the rotor very slighty stoping then i let on the gas the car jerks lightly forward as if the brakes where stuck
Can you guys please help me dont know whats causing it?
https://linustechtips.com/topic/449795-car-problems/
1 could be normal. Many cars start at a higher RPM when its colder, and come down after a few minutes. The fluctuation could be from the AC compressor kicking on and off, that can cause the idle to seem like its surging even though its normal.
2 could be seized calipers or pins/pads that were put on without lubrication. I would get that checked out.
5800X3D / ASUS X570 Dark Hero / 64GB 3600mhz / EVGA RTX 3090ti FTW3 Ultra / Dell S3422DWG / Razer Deathstalker v2 / Razer Basilisk v3 Pro / Sennheiser HD 600
2021 Razer Blade 14 3070 / iPhone 15 Pro Max
https://linustechtips.com/topic/449795-car-problems/#findComment-6030583
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/449795-car-problems/#findComment-6030591
