So I just stress tested my CPU, which I don't think I've ever done with it before, after about 30 seconds it hit the set 90c safety limit in the mobo and shut off, I have a all in one cooler (single radiator though, i'm poor) is it normal?
- CPU: Intel i7 3770 - GPU: MSI R9 390 - RAM: 16GB of DDR3 - SSD: Crucial BX100 - HDD: Seagate Barracuda 1TB -
https://linustechtips.com/topic/447965-reached-90c-while-using-prime-95/
Definitely not normal. Re-sit the block onto the CPU using new thermal paste and report back.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
Forgot to add it's a 3770k.
No, I would check that the pump is running and that the cooler is making contact with the CPU. Also, are you OCing?
Nope, current mobo would probably explode if I attempted to OC.
try another stress test, aida64 or cinebench.
What is the cooler? Some people automatically assumed it's water without you specifically saying so.
Crosshair VIII Dark Hero | 5900X | NH-U14S | Asus X Noctua RTX 3070 | MP600 | 850 EVO 250 GB | Caviar Black 5 TB | SS-860 XP2 | Define R5 Black | Thaulab Varna IV -> Objective 2 -> Sennheiser HD-555/AKG K7XX/Audiotechnica ATH-M40x
CoolerMaster Sedion 120v Plus
Get yourself a proper board.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Weak motherboard vrm probably. I only hit 90C in Prime 95 when running 1.4V+ on my 3570k.
Since you've got 'Some crappy business board' it might not be enough processor while being stress tested.
You know you can check there profile in-case it is listed there? The wonders of the internet.
It was hanging around 80-86 on Cinebench.
It's a GA-B75M-D3H if you wanna know.
EDIT: I should add I have rev 1.0 with only the 4 pin cpu power connector.
Edited by airdeano
I do think it would be the motherboard VRM not being able to handle the heat/load. Since it wasn't designed to be used in that scenario.
Also you aren't able to overclock on the older B75 boards either - not to my knowledge anyway. It would indeed probably explode.
Are u guys all on crack ?
A 3770 overclocked will easy hit 90 in prime small fft
Intel burn test and aida 64 if the vcore is not static
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
It's not even overclocked.
90c is insane on water assuming it's a custom loop?
REDLINECore i7 6700k 4.8ghz 1.37v.Noctua NH-u12s.MSI Z170A Gaming M7.16GB Kingston Hyper X Fury Black.MSI Gaming R9 390 8GB Crossfire + GTX 780 PhysX.Samsung EVO 850 500GB SSD.Fractal Design Define R5 Midi Black.SeaSonic X Series 1050w Gold.Logitech G302 Deadalus Prime.Ducky DK2108 Zero Mech Cherry Blue.
All in one CPU cooler with push pull configuration
Check the pump is at it's peak potential.
When I ran my i7 with a cheap sedion v12
Push pull I still got 90's at stock
Have u lowered ur vcore as by default mobos
Tend to overpower chips at stock
also (1600)
