Ok so lets start off with sample question
What is coin mining?
What I know:
There is two different kind of coins litecoin and bitcoin, Which is better?
You can make money off it
What i Don't know
What do you need for coin mining?
How old do you have to be?
Can you use a laptop to mine bitcoins?
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/44695-help-me-understand-coin-mining/
It's honestly not worth it, the amount of power a rig would draw compared with the amount of coins you get is usually at a loss.
  1. Coin mining in essence is figuring out various mathematical equations, the person that solves it gets a coin.
  2. You need a computer, preferably with a GPU and a hell of a lot of power.
  3. Not sure.
  4. I wouldn't recommend it.
Plus im guessing you have a laptop since you asked that as a question, you can mine on a laptop, but youll never mine quickly enough to get some coins so you might as well not do it
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
What I know:
What i Don't know
Here you go.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
Coin mining is the act of setting you computer, to gather up all the transactions and combine them into blocks for the public ledger. Once a block of transactions has been compiled it is uploaded to the network and checked, the client is then rewarded 25 bitcoins (or other coins) plus the transaction fees from those transactions. It is an automated process that requires a lot of horsepower.
There's actually dozens of coins and variation. Here's a list of a few coins that are on exchanges and their mining profitability against bitcoin. http://coinchoose.com/index.php
There are two primary algorithms they use. Bitcoin uses SHA-256, Litecoin uses Scrypt. The difference between them for basic knowledge right now are ASIC miners you see advertised for bitcoin, will only work on SHA-256 based coins. They cannot work on Scrypt coins. Scrypt also is more difficult of an algorithm in terms of hash rate. SHA-256 is referred to in M/hash, Scrypt is K/hash. Where 1500 K/hash is pretty equal in terms of conversion to 1500 M/hash.
You can make money off of it, but you are more so investing into the future of the global economy outside of banks and government centralization.
There is no age required
And you cannot use a laptop to mine. (You can, but you won't get anywhere with it)
Here's a post I made explaining a little bit more of what bitcoin is.
http://linustechtips.com/main/topic/43490-100-noob-here-needs-help/?p=568447
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
  3. Not sure.
BUT i don't pay for power?
no, but your parents do.
I don't really know any way else to describe that except as unethical.
You also need mid/high end (7850 / 5830 or better) AMD GPUs to get anywhere.
He could also be running it at his workplace or his school.
How do you know his Parents pay for power?
For example, my Rent for my apartment includes Electricity all-inclusive. So in this case, the building management pays for the electricity, but considering how much they charge me, I don't give a damn if I use more power than regular users.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
if my memory serves correct hes around 13.
i use the forums a lot since the interim of fall and summer semesfers, being jobless and all.
Error: 410
