4 7990 for coin mining?
Go to solution Solved by RuecanOnRails,
Hey guys, can you not get off topic and stop posting FUD about Bitcoin and other cryptocurrencies, Tthank you. The OP is asking a legitimate question in regards to running quad 7990 in a mining rig.
First, You cannot run that many gpu's each card counts as two and I'm pretty sure there is a hard limit of 7 GPU's that can work on one board for mining. If you wanted to get 4 7990's you would need 2 mining rigs. Place 2 cards in each, then you can add 3 more single cards, Or 3 7990's in one rig. However you want to divide them so you can get 7 cards per rig.
Second, the 7990's run the GHZ bios which doesn't mine very well at all. You will likely see an average of about 585 K/hash per gpu core 1170 khash per 7990 when mining scrypt (you don't mine SHA-256 with gpu's at this point)
Third, If you were to get individual 7970's they are easier to manage, and get to a higher hash rate. A 7970 can get 725 - 750 Khash each card. They are also cheaper.
Fourth, Build the mining rig in a milk crate or some other open air container using PCI extenders to separate the GPU's for better air flow.
Hope this helps answer your initial question.
I just watched Linus's 7990 showcase. Could three or 4 of these be used for folding or mining?
I already know 4 gpus is the max for regular use but does the same thing apply for mining/folding? I have used a two 7970 setup and they seem independent but coding etc is way over my head
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/
The heat output would be tremendous, not to mention the power it would draw.
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586172
You'd need a VERY good ventilated case for that indeed.
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586181
Since when can you do more than 2 7990's?
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586189
There is no point in coin mining to be honest. It is a bubble currency. Laws and taxes will be slapped on it soon and the final blow that will bring these crypto currencies to their knees is the fact that coins will just be too hard to mine for most people, this will get rid of the appeal of the currency.
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586190
what case ? lol this system will need open air usage
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586193
Why is everyone still so dead set on GPU mining, its not cost efficient at all, if you want to mine i recommend picking up some ASICMiner Block Eruptors. They are little ASIC chips that run off of usb power and they kick the snot out of any GPU in terms of performance/watt.
One of these little guys runs you about $67 and nets you 330M/hash. 4 of them could trounce a 7990 for about $250 and you would have a total power draw around 10Watts compared to 375  watts with the 7990, also it would only take around $5 a year to keep them mining 24/7.
ASICs are the way of the future, this setup would be very upgradable as you would just need a large USB hub to keep plugging these things into. I actually run one myself with 4 of them linked to a Raspberry Pi, its dead silent and produces next to no heat.
Here is an example of this system, this one pulls 11.8 GH/s, far more then any GPU farm and only draws the power of a very low end GPU:
Here is a guide if you are interested:
http://learn.adafruit.com/piminer-raspberry-pi-bitcoin-miner/initial-setup-and-assembly
Here is a link to one:
http://www.ebay.com/itm/ASICMINER-Block-Erupter-USB-Bitcoin-ASIC-Miner-NOT-BFL-or-AVALON-In-Hand-/171098801276?pt=LH_DefaultDomain_0&hash=item27d648847c
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586198
Not really, one thing cant be taken away and that is ease of use, which is a bigger factor, as for mining well this isn't for grandma and grandpa, most people are too scared to even touch a computer let alone setup miners and configuring them.
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586215
Am I still the only one reading this correctly where he's asking about '4' 7990's?
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586235
Mining doesn't require crossfire as far as I know
Intel Core i5 4670k 》Asus Z87 GRYPHON 》8gb Corsair Vengeance 1600mhz
Asus R9 280 STRIX 3GB》Samsung 840EVO 250gb 》Seagate Barracuda 2TB
Corsair GS 800W 》Corsair 350D Case 》Corsair Hydro H110
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586251
If you can afford 4 7990 you can afford a small custom loop to cool them. Then you wont have any problems ^^
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586277
the law will come and the taxes.
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586328
But technically they won't work?
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586333
well yes *rolls eyes*, Bitcoin is already declared an Official Currency by the US government. The idea behind bitcoin is that is an easily subdivinded currency with no central bank/source. This will always ring true, the government can tax it, but they cannot control production of it. That is they key as they cant simple "print more bitcoins" like the US dollar.
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586341
it is not worth it for gpu miners anymore.
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586399
 Thats why I mentioned the Block Eruptors, Mining on GPUs is not worth it. The OP wanted to buy hardware just for bitmining, to do that with GPUs would be foolish and costly
I also have a post just on the Block Eruptors:
http://linustechtips.com/main/topic/44678-kill-your-gpu-bitcoin-mining-with-block-eruptors/
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586412
the us government cant control it.....its not theirs to control......bitcoins are all over the world......no country will be able to tax it or control it.....unless the world government makes a set of reglated standard rules that all contries follow to regulate the currency it cant happen.....a judge somewhere has only recently declared ti a currency......also the governments isnt making the bitcoins, users are.....if everyone started printing dollar bills they would have no control over USD....
also do what yellow dragon suggested with those usb things.....better and cheaper for your purposes....
-Anubikai
| i5-4670k at stock until I do a custom WC loop | H80i | Asus Matrix Platinum 7970 at stock until I do a custom WC loop  | MSI Z87 GD65 | 1TB CAVIAR BLACK | 250gb Blue Scorpio | HX750 80 PLUS GOLD modular | 16GB INTEL EXTREME EDITION PATRIOT 1866MHZ | Coolermaster Storm Enforcer with two Red 20cm fans intake and exhaust |
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586413
What is coin mining?
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586443
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-586460
Thank you :)
https://linustechtips.com/topic/44671-4-7990-for-coin-mining/#findComment-587476
