I want to build a "Gaming Rig" I was wondering What Specs I would go for.
Things I Have:
AMD A10-5800k Processor
MSI A88X-G45 Gaming Board
8GB RAM 1866
600W 80+ Bronze PSU
256GB SSD
1TB HDD
C920 Logitech Webcam
Feel Free To give your suggestions on what I can/would need to change.
I also need a high end GPU because I would be doing a lot multi-tasking,gaming, sometimes a few graphics designs.
If I need to change Mobo, Could you suggest any? I'm looking for something with the Killer Ethernet 2200
If I need to change CPU, Something I could OVERCLOCK the hell out of.
Budget: $750-$800 USD
https://linustechtips.com/topic/445585-specs-for-csgostreaming/
specs dont matter when your streaming csgo ;)
no sir you need a better cpu
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5971589
Ideally Id recommend a 4690K or 4790K with a Z97 board and a 970 or 390.
No matter how you match these components with one another you will be able to stream CS
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5971595
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5971599
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Directron)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard  ($80.10 @ SuperBiiz)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($41.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($41.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($203.99 @ SuperBiiz)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($32.40 @ SuperBiiz)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($54.00 @ SuperBiiz)
Total: $753.94
Generated by PCPartPicker 2015-09-07 02:34 EDT-0400
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler  ($46.99 @ Newegg)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($313.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($62.10 @ SuperBiiz)
Total: $777.16
Generated by PCPartPicker 2015-09-07 03:04 EDT-0400
CPU: i5-4690 | CoolerCRYORIG H7 |GPU: PowerColor TurboDuo R9 280X OC RAM: G.skill RipjawsX 8GB (2 x 4GB) DDR3 1600 CL9Motherboard: ASUS B85M-E | SSD: ADATA XPG SX900 128GB |HDD: Western Digital Caviar BLUE 1TBCase: Cooler Master K281PSU: SeaSonic ECO 600W | Monitor: Samsung S24D390HL 24 Inch PLS
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5971680
Sell the CPU and Motherboard to get enough to build this.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($317.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($113.99 @ SuperBiiz)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard  ($96.98 @ Newegg)
Storage: Sandisk Ultra Plus 256GB 2.5" Solid State Drive  (Purchased For $0.00)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.98 @ SuperBiiz)
Total: $848.94
Generated by PCPartPicker 2015-09-07 02:46 EDT-0400
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5971722
Total: $848.94
Not the cx pls for gaming/oc build. everything else is fine
Here is my hyperthreading  option (i7 without the intel hd)
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($232.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.89 @ OutletPC)
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard  ($79.99 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($42.99 @ Newegg)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($213.98 @ Newegg)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($41.40 @ SuperBiiz)
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($47.99 @ NCIX US)
Total: $777.71
Generated by PCPartPicker 2015-09-07 04:39 EDT-0400
The site has changed....
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5972193
Total: $777.71
ummm, pay attention to the OP?
I believe he is saying he already has certain parts, ones that we can reuse.
1/2 the items on my list are already bought at $0.00 USD.
I spent $850 on items he needs, I didn't replace every item, cause from they way he put it he already has....
Memory, Storage, and a PSU... he also has a CPU and Motherboard, but they suck, so I replaced those.
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5973179
k
Also you didnt replace the psu(that actually sucks) and you paired it with a high end gaming rig+over budget.Bad call
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($34.90 @ Newegg)
Total: $715.85
Generated by PCPartPicker 2015-09-07 09:07 EDT-0400
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5973195
Thanks A TON guys!! So I went around town and a few computer shops to see what they had in stock.
Let me hear what you think
What I'm looking to buy:
Mobo: MSI Z97 Gaming 3/5/7
CPU Cooler: Corsair H100i Liquid Cooler
GPU: MSI GTX 960 2GB OC
What I currently have from my old PC:
PSU: Corsair CX600M
RAM: 2x4GB Apotop DDR3-1866
Casing: Xigmatek Asgard 382
SSD: 256GB Samsung SSD 2.5"
and 3 120mm Fans.
Then just overclock the hell out of the unit
What do  you think?
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5974012
PSU: Corsair CX600M
and 3 120mm Fans.
What do  you think?
Overclock is not safe with the corsair cx psu.
also better get a non oc cpu and better gpu.(380-390)
mobo maybe asus z97-e or z97-a
Or corsair h60/noctua nh-d14 as cpu cooler
Get antec/evga b2-gs-g2/superflower/xfx/seasonic for psu
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5974181
PSU: Corsair CX600M
and 3 120mm Fans.
What do  you think?
if that is your plan after the recommendations given... all i can say is... GL
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5974231
You should be looking to buy this instead.
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($126.89 @ OutletPC)
Total: $878.85
Generated by PCPartPicker 2015-09-07 12:35 EDT-0400
and honestly that motherboard is a bit too expensive for what it gives, but it's nice because it matches the MSI GPU.
Now if you are an Nvidia fan like myself... you can just get a GTX 970. MSI edition to match the build. :)
i know $878 is over budget, but you might be able to sell that old Motherboard and CPU to make up the difference in price.
the NZXT cooler works better, it has a 280mm Radiator while the h100i only has a 240mm radiator, so the NZXT does a better job at cooling the CPU.
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5974643
Thanks so much for all your help vSyNd1c4t3, Well I'm purchasing these parts in the Philippines though, and I asked the stores/suppliers about the parts. Some are Order Basis only and could be up to 6 weeks before they arrive, but I'll try my best. at this point would it make sense for me to pay the extra $100 bucks or so for the i5 vs the i7 for the purpose I would use it for? Would it make a big difference in terms of performance for CSGO+Streaming? Thanks for all your opinions though.
Lastly Can Anyone Suggest a Good/Decent Liquid CPU Cooler that could go with my "Red and Black" Theme? Can you name 3 maybe? so I can check which are available? Budget: $130 Maximum. Less is better :)
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5975275
ah ok, that makes sense that all the part aren't in your area.
for CS:GO the 4790k isn't going to be much better, if any, better than the 4690k. The streaming part it will make a huge difference. OBS uses multithread technology, and it will help a lot.
Now... I don't know if it's 100% needed, but it will definitely be a huge performance gain on the streaming side, also with any video editing.
https://linustechtips.com/topic/445585-specs-for-csgostreaming/#findComment-5976642
