A quiet efficient fan
Go to solution Solved by HeathCliff,
Seems I misunderstood, I meant a cooler; not a fan. xD Just misworded it, i'm looking for a quieter cooler. Yes.
For £40, the best in my opinion would be the Cryorig H5.
http://www.ebuyer.com/666088-cryorig-h5-amd-and-intel-processor-heatsink-cooler-cr-h5a
Not sure about the noise issue as mines if fairly quiet. As for size, what case are you using?
So, I picked out this fan: http://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2 Mainly because of the good reviews, but the size concerns me; and also complaints that it is too noisy, can anyone pick out a alternative that is quieter please?
Can we keep it around the same price tag. ^^
My build : http://uk.pcpartpicker.com/p/Ck8VkL
[spoiler spoiler=Crimson Skyline]  My build: http://uk.pcpartpicker.com/p/Ck8VkL | I5-6600K | Hyper 212 Evo | Asus Z170 Pro Gaming + ROG Front Base | Axevir Core Series Red 2X8 2400 | Sandisk SSD Plus 240 GB | Western Digital 1TB Blue | MSI R9 390 | Corsair 760T | Corsair 850 RMI | Dell U2515H IPS | Hyper X II Cloud Red | Corsair K95 RGB | Logitech G602 |
[spoiler spoiler=Laptop] I7 3232QM | Nvidia GT635M | 17.6" TN | 1TB HD | 6GB RAM
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/
Do you have a budget? At that price point, the 212 EVO beats pretty much anything.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960223
do you mean CPU cooler? because what you linked is not a fan
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960248
I'd consider any fan up to £40, I don't really understand Liquid Cooling. :P
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960260
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960265
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960280
Thanks, i'll take a look at the H5.
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960282
Will I be able to overclock at least 500 MHZ with the H5? would that be safe?
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960300
That thing is absolutely terrible. The Noctua NH-U14S is the best buy for this budget.
Really? Can you link me to the sources because I've hardly heard any negative comments about it.
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960316
That's the system i've setup. http://uk.pcpartpicker.com/p/nDTg7P
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960321
Can only link a Dutch review.
http://nl.hardware.info/reviews/5720/6/cryorig-h5-cpu-koeler-review-looks-ok-koeling-ook-grafieken-geluidsproductie
Basically the fan is really loud and it cools average. So it's a very inefficient cooling design. Noctua NH-14S is the most efficient fan out there right now.
Meaning, it cools the most at the least amount of noise.
http://nl.hardware.info/reviews/6162/8/29-cpu-koelers-review-getest-volgens-nieuwe-methode-testresultaten-koeling-bij-30-dba-@-10-cm
212 EVO scores pretty shit.
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960343
Thanks for the info. It's quite interesting as I know someone who has one, and doesn't sound all that loud. Maybe a defect? I'll keep it in mind for next time.
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960415
I'd have to agree with Majestic, my U14S is fucking beast mode - especially with a second A15 fan - it ran neck and neck with my D15S for a long time.
The benefit of Noctua's upper range coolers, they tend to be very reasonably priced and are nicely quiet. You get their elite tier quality construction and customer service to boot, which is worth the small extra over something like the Cryorig H5.
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960429
https://linustechtips.com/topic/444748-a-quiet-efficient-fan/#findComment-5960478
