Hybrid Storage
Go to solution Solved by Captain_WD,
Hey Captain_WD,
My desktop rig has more than one bay.  I currently have one 1TB Western Digital Black drive installed.
I would be loading my OS onto the SSD and using the HDD for everything else.  Was just wondering if it's a better buy for an SSHD on a desktop.
I wouldn't imagine so. Having two separate drives (SSD+HDD) on a desktop would be what I would prefer. Having your data on two separate drives gives you some safety in case something happens with one of the drives and needs replacement or if you need to simply move it on another computer. Moreover, you have the freedom to choose what to go on the SSD, regardless of how often it's used and you have much more space there while with a SSHD you can't decide what to be cached and you are limited to quite a small amount of fast storage.
You plan seems pretty good (putting the OS on the SSD and use the HDD for everything else) :) this is what I would do.
Captain_WD.
Was thinking of buying a hybrid SSD/HDD and was wondering if they are good or if I should just stick with buying seperately.
Here's the one I was considering buying by Western Digital.
http://www.canadacomputers.com/product_info.php?cPath=15_1086_215_217&item_id=085020
Good idea?
// Floatplane Pilot //
Main Rig:  Motherboard: ASUS H270 - PLUS - CSM | RAM: Corsair Vengeance DDR4 16GB (2x8GB) | Case: Corsair Carbide Series SPEC - 02 | SSD: ADATA SU800 128GB HDD: WD 1TB Hard Drive | PSU: Corsair CX 550M | CPU: Intel Core i7-7700 Cooling: Cooler Master Hyper 212 EVO | GPU: ASUS GeForce GTX 1070 | Keyboard: Logitech G710+ Mechanical | Mouse: Razer Naga 2014 | Sound: Corsair VOID RGB / USB Headset | OS: Windows 10
Laptop:   Razer Blade Stealth 2016
https://linustechtips.com/topic/444284-hybrid-storage/
Buy a seperate SSD and HDD if you have the room for it.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5954455
I absolutely have the room for it.  Was just wondering if it reduced speed/performance at all?
if money is an issue then yes
Money is not an issue as long as it's >$250 CAD....
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5954469
Buy a 120/250 gig SSD and a 1TB HDD depending on the price.
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5954472
then get a SSD and a HDD. much better
Okay, so that maximizes performance of writing/reading?
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5954473
unless you absolutely need it for a laptop with only 1 drive bay, get a separate SSD+HDD
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5954496
Okay, got it!
Thanks guys!
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5954525
Good idea?
Hey there ShadowDeity,
SSHDs are great solutions for single-bay systems (usually laptops) that are mostly used only for a few things. They use an algorithm to determine what is mostly used on the system and store the load files of those applications (including the OS) on the SSD portion of the drive (which is usually 8GB) for much faster loading and smoother operation. The rest of the things work normally just as on any other HDD.
Combining a standalone SSD with a separate HDD can have more benefits as you will have the freedom of choosing what to install and store on the SSD, have some redundancy of the data (of one drive fails, the other would be still healthy and accessible) and you will have much more space on the SSD at your disposal.
What are you going to use the storage solution for?
If you have a single-bay system and still need more performance, I can also suggest checking out WD Black2. It's a dual drive and, unlike hybrid drives, it consists of separate 120GB SSD and a 1TB HDD part all in the same 2.5" form factor. The two parts of the drive work separately and are treated just as regular two separate physical drives. Here's a link: http://products.wdc.com/support/kb.ashx?id=ccHFm2
Feel free to ask if you happen to have questions :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5971816
Captain_WD.
Hey Captain_WD,
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5979023
Hey Captain_WD,
Captain_WD.
https://linustechtips.com/topic/444284-hybrid-storage/#findComment-5980001
