Will this work good for a security system?
i just need to know if this will work ok
http://www.newegg.co...N82E16881147039
 http://www.newegg.co...82E16822178393
needs:
Night vision
Motion detection
on 24\7
under $300
4 of them
THAT MOMENT YOU DISASSEMBLE YOUR COMPUTER....AND REASSEMBLE IT ....JUST SO SENPAI WILL NOTICE YOU
https://linustechtips.com/topic/444212-will-this-work-good-for-a-security-system/
your second link is broken
it says it supports drives 2TB or less, so if that HDD you tried to link is 2TB or less then yes it will work
ok, so just type "
SHIELD Series RSCM-0704B041
" in neweggg search
ok, so just type "
" in neweggg search
i said second link, not first
the HDD link
the HDD link
sorry bro, its the
Seagate NAS HDD ST4000VN000 4TB 64MB Cache SATA 6.0Gb/s Internal Hard Drive
the HDD link
http://www.newegg.com/Product/Product.aspx?Item=N82E16822178393
There's a fking space at the end of the link come on
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
sorry bro, its the
no it will not work
that system only supports 2TB hard drives or less
and why
no it will not work
Can you link me to a good drive ? i heard WD purple is for this...please adn thanks
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236661
Guest
