cpu only using .77ghz?
Go to solution Solved by robert1339,
Change the power options to High Performance
so I have been wondering why the fuck my computer is so slow and I see lfoxPNt.png
it says I have all my cores yet only running .77ghz? how do I fix this?
CPU: i9 19300k////GPU: RTX 4090////RAM: 64gb DDR5 5600mhz ////MOBO: Aorus z790 Elite////MONITORS: 3 LG 38" 3840x1600 WIDESCREEN MONITORS
https://linustechtips.com/topic/443821-cpu-only-using-77ghz/
It's just idling, you're probably not doing much now.
Maybe try changing the power settings (if it's a laptop) and check the temperatures
https://linustechtips.com/topic/443821-cpu-only-using-77ghz/#findComment-5948108
Run Cinebench and watch it shoot up
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/443821-cpu-only-using-77ghz/#findComment-5948110
