Shocked by my case, need help
Solved by W-L,
-SNIP-
You should use a grounded outlet an easy way to test is to use an extension cord to another properly grounded outlet in the house. Without grounding, devices and built up a charge that can shock and potentially injure or kill the user if it has the ability to build up such a high voltage charge or there is an issue with the device and it shorts to the metal PSU casing. It sounds like it's not too much in your case but always use grounded outlets for devices that have a grounding pin.
