Dual Monitor Noob Here. Please Help!
Go to solution Solved by Cacao,
Here's what you do:
a) connect the second monitor to your graphics card (use the best cable you have available, best option is DVI)
b ) right click on your desktop and go to "Screen resolution"
c) Here you should see your two monitors, drag the boxes so the setup on the screen looks exactly like the one in front of you, in my case it looks like this:
If one is higher than the other or is on the wrong side make sure to adjust it accordingly. You can click the "identify" button on the right so you can see which is which.
d) Next make sure you have the following config:
  -Click on your main 1080p monitor and me sure it says "This is currently your main display", if it isn't, check the little box.
  -Click on your secondary monitor and under the "Multiple displays" menu set it to "Extend desktop to this display"
Once you've done that hit apple and you're done. You can now drag windows from one display to the other and whatever you put on your second display you'll be able to see once you go in a game on your primary display.
Hope this helped!
@nikg307
Hello people of Linusville!
I have recently become interested in running dual monitors so that I have chat and media windows open whilst gaming.
However, I don't want to have to buy a new monitor.
My current setup consists of a MSI HAWK GTX560TI and a Benq GW2250 monitor running at 1080p.
I have a spare Acer V203h monitor which runs at 1600x900.
I was wondering if it was possible to set it up so that games and videos would appear on the Benq, while Skype, WMP, Teamspeak, etc. Would appear on the Acer
I'd also like to have different wallpapers on each monitor.
Thanks for any help!
My Build: Intel Core i5 2500k @4.8GHz, MSI GTX560ti Hawk, Asus P8Z78V-Pro Gen/3, 8GB Mushkin 1866 RAM, Corsair H100, NZXT Tempest
https://linustechtips.com/topic/44286-dual-monitor-noob-here-please-help/
yep possible. running a 1080p main monitor and a 1440x900 as my secondary. I use windows 8 so setup for multiple monitors is amazing
msi h77ma g43
i5 3470
Coolermaster hyper 212 evo push+pull
Powercolor 7950 pcs+ @1100 mhz core 1400mhz mem
Coolermaster haf 912 advanced 120mm rear, 200mm top 200mm front
Corsair vengeance 2x4gb 1600 MHZ
Windows 8 64bit
Silverstone essentials 500w ST50F-ES
Samsung dvd drive
2x 250GB Hitachi RAID0
Seagate Barracuda 2tb
LG IPS235p
Razer Blackwidow
Razer Deathadder
When you right click desktop and go to your monitor settings, you can apply your 1080p monitor to be priority "1" and then full screen applications like games should automatically run on that screen. As for other programs, all you need to do it drag the window over to your 2nd monitor and you're set.
Don't forget to mark as solved ;)
GL HF
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
It will be fine. Benq as the main and the other for anything else you need to do. Its not like triple monitor setup where you need three of the same monitor
Nzxt Phantom 410 - I5 4670k stock - 7950 vapor x @ 1000mhz/1250mhz - Msi Z87 G45 - 8gb Corsair Vengeance pro 1600mhz - TX650 - Benq XL2420t - Blackwidow Ultimate 2013 - Deathadder 2013
Here's what you do:
Hope this helped!
@nikg307
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
For having different wallpapers on each you have to get a program called  DisplayFusion, it's on steam and it's 30 dollars. It can also do other things like making the task bar go to both monitors.
there is a free version as well which will pretty much supply all of your needs for the average user using 2 monitors
Thanks for all the responses!
I didn't realize that running dual monitors would be so simple.
I'll definitely try out DisplayFusion once I get everything set up.
