hay guys this is my current build http://pcpartpicker.com/p/w2Nvyc does anyone know a good cpu to replace that one for my build i want it to last 5 years and i want to be able to run top notch games like ark rust,subnatica, etc on highest settings. I'm not going to over clock and i'm running at 1440p thx for the help. if my current cpu is fine im ok with keeping it, i was just told dont use it if you not going to overclock to save some cash.
https://linustechtips.com/topic/442194-cpu-help/
What's your current rig? There's no link, no sig, no nothing there.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/442194-cpu-help/#findComment-5926655
hay guys this is my current build does anyone know a good cpu to replace that one for my build i want it to last 5 years and i want to be able to run top notch games like ark rust,subnatica, etc on highest settings. I'm not going to over clock and i'm running at 1440p thx for the help.
i don't see anything, or becuase my webmaster blocked pictures.
https://linustechtips.com/topic/442194-cpu-help/#findComment-5926657
There is no reason to upgrade your CPU. You won't see any benefit.
https://linustechtips.com/topic/442194-cpu-help/#findComment-5926679
there is for me
K, now that you edited, I can see something.
Anyway, there's no CPU to replace your build. Yours is already on the top of gaming, it should last your 5 years without a problem, Same thing for your GPU. There's just no way to gain more performance for 1440p.
https://linustechtips.com/topic/442194-cpu-help/#findComment-5926683
Actually there is. But that also depends on his monitor's refresh rate.
For a 144Hz monitor it would actually be worth it to get another 980Ti.
https://linustechtips.com/topic/442194-cpu-help/#findComment-5926721
