need advice on future build.
Solved by CatFromSpace,
I'd do something like this, you've got a 4790k with a 120mm AIO which'll give you a bit of room to do some OCing but I don't reckon it'd be necessary, it's at 4GHz at stock and boosts up to 4.4 so...
I aimed to get everything in that case because it's so damn small. You can fit it in a backpack, no kidding.
Didn't include a disk drive because that case doesn't have space for one and you can just image the windows 10 install disk to a USB stick using another machine. If you really want one, an external one'll come in much handier. You could just get a normal disk drive and one of those SATA to USB converters you can get from ebay for like £3.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor (£252.00 @ Aria PC)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler (£49.99 @ Dabs)
Motherboard: Asus Z97I-PLUS Mini ITX LGA1150 Motherboard (£114.99 @ Amazon UK)
Memory: Kingston Savage 8GB (1 x 8GB) DDR3-1600 Memory (£33.15 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£72.50 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£38.98 @ CCL Computers)
Video Card: Gigabyte Radeon R9 390 8GB Video Card (£249.99 @ Dabs)
Case: Silverstone Sugo SG13B Mini ITX Tower Case (£35.99 @ Scan.co.uk)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply (£65.51 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM (64-bit)
Total: £913.10
Generated by PCPartPicker 2015-09-01 17:57 BST+0100
