So this is how I currently get internet connection from my modem to my PC:
Modem > Switch 1 > Powerline LAN adapter > through the powerline to powerline LAN adapter receiver > Switch 2 > PC and PS4
The problem is that I get 160MB down but only have 30-35 down (speedtest). The current adapters I have are "Sweex LC503 PL Kit 2x 500Mbit White" and I'm looking into getting "NETGEAR POWERLINE PL1200".
Will the upgrade from 500mb/s to 1.2gb/s adapters make any difference in the actual download speeds I get on my PC?
(The second switch doesn't not cause any loss of speed as I have tested it without and I have the same speeds.)
Thanks in advance
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/441150-powerline-lan-adapter-question/
but the optical LAN cable is so cheap... why do people bother with these?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
This is the best thing I can do to get internet to my PC, I'm not allowed to drag a LAN cable across the house, so that's a no-go
well... try a direct connection from the modem to PC first check the speed there.
Also if the current powerline solution is rated for 500 mbps then maybe it just can't do more because of all the intereference in your powerline...
But if that is the only way then it's worth trying.
Go to the shop where you are intending to buy the kit and explain them your situation, and ask if your could possibly test the thing and return it back if it doesn't provide any more speed.
but the optical cable is so cheap... and you can route it trough walls, the cable doesn't have to be on the floor
I can return the product any time for free in this shop so that's not a problem. I guess I'll try that
Go for it!
Together we can!
Don't let the dreams be dreams!
And post pics with an update when you're back
Powerline is like WiFi, the number on the box is theoretical. So that's your answer here, it's not giving your full 160Mbps because no powerline kit will give you the full 160Mbps in most scenarios. That said 35Mbps is a bit low so, it may be just a particularly dodgy AV500 kit.
Test what speed you're getting from your router. If it's 35Mbps there to then it's your connection and not the powerline adapter. If it is the powerline adapter? Then a better kit will give you more speed. For AV500 you should be getting around 70Mbps. If you go to AV1200 then you can expect closer to 130Mbps or so.
Fools think they know everything, experts know they know nothing
Yea I've tested directly from the router and I get the promised speeds there. They always told me a powerline loses a lot of speed, but I will test this new one and see what it does. Thanks :)
Go for it!
Together we can!
Only memes can melt dank dreams. Will do ;)
Is it plugged into an extension cable? If so that's your issue.
Yes it is
Yes it is
That's your issue. Either find a spare plug socket that's empty and plug it into there or take back your current powerline adapter kit and get one with passthroughs on it. I have better experiences with NETGEAR powerline adapters, just saying.
Currently it runs through 2 extension cables, The low speeds may ge up with a passthrough one directly into the net and then the extension cable in the pass through part?
I don't really understand waht you're saying
I don't really either when I re-read my own shit there... lol.
But I'm getting a passthrough adapter now, sadly I cannot get hold of a netgear one in Belgium. You think this one is good? "DEVOLO DLAN 1200+"
DEVOLO is good :)
DEVOLO is good :)
Why dont you get 2 access points and and set it up. One AP can be between your router and pc and another at ur pc. You can plug the second one to ur network switch and u have internet.
Go for it!
Together we can!
Hello guys, I've installed the pass through poweradapters and tested my speeds. And holy hell it worked :o
New speeds: 4627037568.png
To me hearing that is insane. My dad encouraged me to get on the roof with him to cable to my new room when I moved my setup.
Also, good to see that your problem's solved. You probably already know this but a piece of advice with powerline would to avoid any surge protectors.
Sig under construction.
