air vs water cooling
Go to solution Solved by 79wjd,
i dont mind having a big air cooler.
Well, then I would go for a Be Quiet! Dark Rock if you want a black anodized heatsink. Alternatively, if you don't really care, then a Noctua NH-D14/D15. There is also the Cryorig Z1/R1.
I'm not positive what the clearance of that case is for the cooler, so just double check that. (Although I would probably go for a difference case, but whatever)
should i get an air cooling or liquid cooling cpu cooler? which is more reliable? obviously liquid cooling would be a lot cooler, but for overclocking a i5 4690k should i use a water cooler or air cooler?
Intel Core i5-4690k EVGA GTX 980 Ti Gigabyte Z97-UD3H(blackedition) Corsair 850RMx 16GB Kingston FURY hyperX 240gb sandisk ssd 250gb samsung evo ssd H440 black and blue corsair k95 RGB Logitech g502
https://linustechtips.com/topic/440904-air-vs-water-cooling/
High end air coolers are just as good as AIO's. So it comes down to which look you prefer. (Also, Air coolers are more reliable, since AIOs have liquid which slowly evaporates, and has a pump which can fail)
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909490
that depends on the AiO
no air coolers perform better than a 280mm AiO
and only some air coolers are similar to a 240mm AiO
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909537
Air cooling, currently the cryorig r1 ultimate sells for £60 and a h100i sells for £95-£100
for the Lower price you get a cooler that may be big but also cools better and is also a lot cheaper and won't ever have the chance of pump failure
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909541
any suggestions? im building my first gaming pc and i really dont know what cpu cooler to get. right now i have stock
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909556
Get the cryorig r1 ultimate, but first what case do you have ? This is the review of the cryorig r1 ultimate.
http://www.hitechlegion.com/reviews/cooling/heatsinks/39900-cryorig-r1-ultimate-cpu-cooler-review?showall=1&limitstart=
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909578
Well, first decide what aesthetic look you want. Do you want an AIO or a giant metal tower (which can come in black anodized metal as well as silver); and if you're willing to take a hit in noise levels and durability for an AIO.
The Z1 looks nicer :P
PSU Tier List | CoC
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909583
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909628
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909635
PSU Tier List | CoC
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909658
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909697
i would go with a different case now too looking back on it. but oh well. ill look into getting the Cryorig R1.
https://linustechtips.com/topic/440904-air-vs-water-cooling/#findComment-5909699
