There seems to be a big argument going on about this no-one is ever sure what technique of applying thermal paste is best.
I very recently found an amazing source of information for this; http://www.arcticsilver.com/methods.html
It describes the correct application method for every CPU out there.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/4405-how-to-apply-thermal-paste-correctly/
is more expensive thermal paste worth it, i mean i need new stuff so should i just spent 10 bucks or 25? would i see a noteable diference?
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
is more expensive thermal paste worth it' date=' i mean i need new stuff so should i just spent 10 bucks or 25? would i see a noteable diference? [/quote']
I don't think anything does cost more than $15 anyway.
Here are the charts for you:
http://www.maximumpc.com/article/features/geek_tested_17_thermal_pastes_face?page=0,1
(the AS5 in those results was not burned in)
You decide.
To answer the main question' date=' you can refer yourself to Linus with his "As fast as possible" series [url']
No you can't.
If you read the guide it tells you have to apply thermal paste for every CPU and shows you where the cores are located under the cover. For EVERY CPU.
Linus also did not go over pre-applying the paste beforehand to get rid of imperfections on the CPU and heatsink.
That guide is for complete beginners.
Investing in a good thermal paste is worth it. You can probably see a 3-5degree C difference between a good thermal paste and a standard one. (When i say good i mean AS5)
http://youtu.be/-hNgFNH7zhQ shows how different application methods work out
Nothing should cost more than 15 dollars except indigo Xtreme. I heard many good things about it and seems like it is actually the best performer.
Anyone can confirm this?
  • 2 months later...
This thread should be stick, great info. The most complete guide on how-to apply thermal paste according to your exact CPU. Thank you so much for sharing this.
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
I'm going to have some free time these days. So I want to know which Thermal Paste to buy. I'm thinking between Tuniq TX-4 and Arctic Silver 5. I know that the AS5 is amazing, but what about the Tuniq TX-4 ?. I would be happy to read some suggestions. Thank you :)
AMD FX-8350 // ASUS Radeon R9 280X Matrix // ASUS M5A97 Pro // Corsair Vengance 8GB 1600MHz // Corsair RM850 PSU //  WD Green 2TB // Corsair H60 // Cooler Master Elite 430 // KBParadise V60 MX Blue // Logitech G602 // Sennheiser HD 598 + Focusrrrrite 2i2 + MXL V67 // Samsung SyncMaster 245BW 1920x1200 // #killedmywife  #afterdark  #makebombs #Twerkit      "it touches my junk"   linus 2014
good question i wondered that myself
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
thanks for posting, it make sense to do a vertical line for intel ivy bridge because the silcon is down the centre, just realised this.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
Yup. The guide shows where the die is in every chip,  that's why its so useful. ;)
The pea-sized dot in the center works fine for most chips, some chips (like LGA-2011) seem to benefit from a line as they are bigger chips. If I am installing a HDT cooler like my Hyper 212, I use my finger in a plastic bag (or a card) to spread a TINY bit of Thermal Compound between the heatpipes so that it is flush with the mounting surface of the cooler. The Thermal Compound will spread much better.
PC: Ryzen 5 2600 // 16 GB Corsair 3200 // MSI RX 580 8 GB // 500 GB WD Blue M.2 (sata) // Silverstone Raven RVZ03B // Fedora 33
LAPTOP: i7 5700HQ // 16 GB Kingston 1866 // GTX 970M // 250 GB Samsung 850 EVO M.2 // 1 TB HDD // Windows 10
ETC: (2) Dell U2515H (2560x1440) // Corsair K63 // Logitech G603 // FiiO E10 // Beyerdynamic DT 770 PRO (250 ohm) // Audio Technica ATH-M60x
i guess this is a good place to ask, a 4g tube of thermal paste can be used how many time aproximately? never bought aftermarket paste and looking into ic diamond
You only need a small amount so at a minimum 5 applications and at a maximum 10 applications.
I guess just a difference of a few degrees with temps.
Is this the real life? Or is this just fantasy?
Awesome link. I hope this gets stickied.
My Best 2013 Bitfenix Prodigy Build  Case: Bitfenix Prodigy White | Motherboard: ASRock Z77E-ITX | CPU: Intel i7 3770k | CPU Cooler: H100i | GPU: GTX 690
Fan Controller: Bitfenix Recon | Ram: Patriot IEM 16GB @ 1600mhz | Primary Storage: 2 x Samsung 840 Pro 256GB | Backup Drives: 2 x Seagate Barracuda 2TB | PSU: Seasonic X850
Dang, Arctic Silver 5 for $13 a tube? I bought mine off Amazon for like $2...
Intel 2600k @ 4.5 GHz | CoolerMaster 212 Evo | ASUS P8Z68 Deluxe | XFX 7950 Black Ed. Corsair Vengeance RAM (4x4GB)NZXT Phantom 820 | Rosewill 1000w Bronze
ASUS VN248H-P IPS | LG E2742 | Logitech Z623 | Logitech G600 |Steelseries QcK Heavy | Corsair K90 MX Red | Ducky Shine Year of the Goat MX RedErgotech Freedom Arm
Looks like the price went up. O.o
Maybe... I bought mine a year ago so maybe I just got in at a good time. :D
