Yeah it's possible, but I'm not sure how to configure them. Google is your friend :)
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
yep dont get any plans of sli thow
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
yes it will work
one can be used for one thing while the other GTX is used for gaming
a lot of people have quadro+gtx systems with both cards at a time, but im not 100% sure how having two different GPU drivers works
obviously youi cant use both cards for the same thing since you cant sli them
also you can mix an AMD card in, that wont work
Yes;
You use the Quadro for display outout but force gaming using the other card. Its effort to do -> you could also use a displayport switcher/multiple ports on same monitor and swap inputs (probably), but doing it in software is a pain (took me a good day or 2 of tinkering to get to work).
What I plan to do is use my Quadro card while using GTX 960. I want to use my GTX 960 for gaming and the Quadro for school work and rendering in Sony Vegas and other programs. This is for a new build I'm doing.
Can you clarify exactly what you're trying to do?
Do you want to Render on the Quadro WHILE gaming on the 960?
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
Swapping the cards out, yes, but the two cards at once, maybe
Yes it is possible
[spoiler=My PC]
CPU: Intel Core i7 6700K | COOLER: Corsair H105 | MOBO: ASUS Z170i Gaming Pro AC | RAM: Corsair LPX DDR4 16GB 2400MHz | GPU: EVGA GTX 980 Classified | CASE: BitFenix Prodigy | SSD: Samsung 950 Pro 512GB | PSU: XFX XTR 650W [spoiler= Le Other Stuff] Monitor: BenQ XL2411Z | Keyboard: Ozone Strike Pro | Mouse: A4 Tech X7 F4 | MousePad: Ozone
PlayStation 2 | PSP 2000 | Game Boy Color | Nintendo DS Lite | Nintendo 3DS | Wii
Sony Xperia J (Why u so bad D:) | iPod 4th gen | iPhone 4 | Yarvik Xenta 13c (3muchchrome5her)
Pentium B980 | 500GB WD Blue | Intel HD Graphixxx | 4Gegabeytes of REHAM
Current OS: MSX 10.0 ( ͡° ͜ʖ ͡°)Ilikethelennyfaceyouknow( ͡° ͜ʖ ͡°) Windows Password Reset Guide
What I want to do is have both of them running on the system. When I am gaming I want to use my 960 and when I'm not and doing work for school and stuff I would really like to use my Quadro.
But you are using them at different times, correct? So you do some gaming, then, afterwards, you render a video, etc.
In this case, yeah, no problem. Ideally, you would also swap the monitor between whichever card you want to use. Some programs will allow you to select which GPU to render with, but some will just use the default GPU (Which is the one that the monitor is plugged into).
Love the idea, but which drivers do I ideally would want to use?
You would install them both.
Use the GeForce driver when installing the GTX 960, and use the Quadro driver when installing the Quadro.
