My FX9590 keeps overheating under load
Solved by linuxfan66,
On earth do you overheat a socket....the most extreme Intel overclocks ive seen can't overheat a socket...it is probably your motherboards CPU socket that is overheating. Unless you have the Sabertooth 990FX R2.0 or Asus ROG Formula Crosshair, AMD does not guarantee that your mobo will handle the 9590.
Those two motherboards are the ONLY ONES that AMD is confident can handle the TDP.
Also, follow your own topics
Featured Topics
Tamgam12 ·
remo233 ·
Posted in New Builds and Planning11 -
1
6
10
rickymohk ·
Posted in General Discussion3 -
Rbakker02 ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion5 -
2
