Hi there!
I want to upgrade from my nearly 4 year old Toshiba Satellite to something that can handle heavier loads and run some games.
The intent of the workstation is primarily Software Compiling, Video Editing, 3D Rendering and a decent amount of gaming.
The programs I'll be using primarily are:
Unity
Visual Studios
Android Studio
Adobe After Effects, Flash, Photoshop
The games I'm looking to run are:
Rocket League
Hearthstone
GTA V
Nothing crazy like Witcher 3 highest settings, but enough to play those games without stutter.
I've put together PC's before, but never picked out the parts. Regardless I did some looking and came up with this build: http://ca.pcpartpicker.com/p/s4b8gs
Some choices like the RAM I just went all in with to give myself a ball park figure, but I realize I may not need that much. I will be starting off with 1 monitor (none chosen yet, a not too expensive suggestion would be appreciated) but eventually will want a 2nd.
This build is slightly more expensive than I intend, but I want it to last for a good while.
Any and all CnC is appreciated. Thanks !
https://linustechtips.com/topic/438332-suggestions-on-first-workstation-build/
I'd try to swap out the GPU for the GTX 950. Other than that, it looks solid. You could also consider an Intel Xeon as there may be an option within your budget that offers Hyper-Threading.
Looks good, but the 750ti will struggle a bit in GTA V. maby a 950 as SLSAMG siad.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
Intel Core i5-4460 3.2GHz Turbo 3.5GHz | 8GB Kingston DDR3-1333 | MSI Radeon R7 370 OC to 1020mhz | EVGA Supernova NEX B1 750W | GIGABYTE GA-B85-D3H | Inwin Velocity OEM Case | 120mm broken fan
Vancouver, BC | O Canada
http://ca.pcpartpicker.com/p/34JMt6
The extra CPU cores will make video rendering a lot faster. I downgraded your SSD and added a cheap HDD because you'll need more storage if you're gonna be making videos. I suggest getting another 1TB drive sometime in the future as well. I also swapped that GPU for a 950, so you can actually run your games [emoji14]
The monitor that I would recommend for this build is the Acer H236HLbid. It's 23", 1080p, and has an IPS screen for better quality colour. It's pretty cheap, coming in at around $170 CAD.
Hey guys thanks so much for the advice! After looking through all your suggestions and asking around some of my friends (I'm studying in Comp.Sci and a lot of them are enthusiasts), I've come to have 2 builds in mind. I would love your inputs on which I should pick.
Both Cases
Changed the PSU to 80+ Gold
Changed cases
Won't need an HDD as I already have a 2TB one on me
Upgraded Video Card as suggested
AMD
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($212.00 @ Vuugo)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard  ($124.98 @ Newegg Canada)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  ($135.98 @ Newegg Canada)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($112.99 @ Amazon Canada)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($440.34 @ Newegg Canada)
Power Supply: SeaSonic 450W 80+ Gold Certified Semi-Modular ATX Power Supply  ($85.69 @ DirectCanada)
Total: $1243.95
Generated by PCPartPicker 2015-08-27 18:17 EDT-0400
Intel
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($320.98 @ Newegg Canada)
Motherboard: MSI B85M GAMING Micro ATX LGA1150 Motherboard  ($113.50 @ Vuugo)
Video Card: MSI GeForce GTX 960 4GB Video Card  ($304.99 @ Memory Express)
Total: $1169.10
Generated by PCPartPicker 2015-08-27 18:23 EDT-0400
Thanks again for all the help, and I'll be sure to check out the monitor.
i'm pretty sure the r9 380 from msi (below) is NOT voltage locked. make sure that your gpu isn't locked so you can overclock it properly
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($35.95 @ Vuugo)
Motherboard: MSI B85-G41 PC Mate ATX LGA1150 Motherboard  ($99.75 @ Vuugo)
Memory: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1866 Memory  ($115.98 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($87.50 @ shopRBC)
Video Card: MSI Radeon R9 380 4GB Video Card  ($327.95 @ Vuugo)
Case: Corsair 200R ATX Mid Tower Case  ($84.04 @ shopRBC)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($86.91 @ shopRBC)
Total: $1159.06
Generated by PCPartPicker 2015-08-30 22:46 EDT-0400
BigDay
what's your budget? don't go with an amd cpu. your build needs work
You can spend an extra $100 to get a 970 on the intel build and in the end it would only be $20 more than the amd.
Is there a big reason not to go AMD?
Also the budget is $1000-1200 roughly.
Here you go.
CPU Cooler: Arctic Cooling Freezer i11 74.0 CFM CPU Cooler  ($31.98 @ Newegg Canada)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard  ($97.99 @ NCIX)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($58.98 @ DirectCanada)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($129.75 @ shopRBC)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card  ($229.99 @ NCIX)
Case: Corsair 100R ATX Mid Tower Case  ($54.99 @ NCIX)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ NCIX)
Total: $994.65
Generated by PCPartPicker 2015-08-31 17:00 EDT-0400
The site has changed....
