6 pin PCI-E connector
Hey guys and gals, okay so I've been on Amazon looking for One 6 pin PCI-E connector Male to Male for my GPU and nothing relevant comes up! just 6 pin PCI-E Male to Female or  to 2 molex!
if anyone could send a link to one (Don't care about color or sleeved) and hopefully inexpensive too!
MANY THANKS :):):):):):):):):):)
https://linustechtips.com/topic/438199-6-pin-pci-e-connector/
Does that even exist?
https://linustechtips.com/topic/438199-6-pin-pci-e-connector/#findComment-5874257
way I ask why?
https://linustechtips.com/topic/438199-6-pin-pci-e-connector/#findComment-5874258
it has Mini in the title.. will that still fit in gtx 760's 6 pin port??
https://linustechtips.com/topic/438199-6-pin-pci-e-connector/#findComment-5874369
Are you just replacing the connectors since you don't like the red color they sell them by the part say at Mainframe Customs:
https://mainframecustom.com/shop/cable-sleeving/6pin-pci-e-female-connector/
https://linustechtips.com/topic/438199-6-pin-pci-e-connector/#findComment-5874405
It should work, but can you take a picture of the back of both plugs so that we can see the wiring? Just to make sure it's wired up the same on both ends.
"Rawr XD"
https://linustechtips.com/topic/438199-6-pin-pci-e-connector/#findComment-5876774
