Help me decide on a case please
So Im moving from MicroATX to ATX meaning new motherboard and case (Motherboard is being upgraded because current one is failing with my graphics card power draw - Cheap ECS essentials class POS)
Im going with the ASRock Z97 for my motherboard.
I would like the case to be
-Sub-100 if possible, 150 max (USD)
-At least 6 Hard drive mounts
-Cable management is biggest priority
-Side window
-Solid build quality feel. (No flimsy hard drive mounts or case doors)
-Separate SSD bay is a big plus, but not required
-Bottom mounted power supply
-No preference between full and midtower
-Practicality over aesthetic design. (Id take a black box with a solid build over some spaceship that feels like its going to fall apart). But I wouldn't mind something that looks nice too.
get the air 540 do not get anything else it only has 2 HDD mounts but it has a shit ton of SSD mounts it has everything you're looking for
