Need opinions
Solved by WoodenMarker,
Where are you shopping/located? Budget?
EVGA and Corsair feature similar psus in that they use their higher end units that are excellent to sell other not-as-good ones that range from mediocre to just okay.I don't recommend corsair cx series, heard way too many bad things about them. I can recommend evga.
The CX series is similar to EVGA's B1 and they're both just okay--nothing particularly bad with either as value psus.
