GTA V HELP! PLEASE!
Go to solution Solved by SImoHayha,
it just says to repair or quit
Ok then your core files might be corrupted. Here follow this reddit
advice
https://www.reddit.com/r/GrandTheftAutoV/comments/32js98/failed_to_load_zlib_fix/
So after hours of troubleshooting and researching this ZLib error this afternoon I finally found a solution that works for me. The Zlib issue was caused by a corrupted file during that download phase.
To fix this, I did the following:
Download WinMD5 from
match all your .rpf file checksums to the following:
  • x64a.rpf - 683610e269ba60c5fcc7a9f6d1a8bfd5
  • x64b.rpf - 70af24cd4fe2c8ee58edb902f018a558
  • x64c.rpf - 2a0f6f1c35ad567fe8e56b9c9cc4e4c6
  • x64d.rpf - c8757b052ab5079c7749bcce02538b2e
  • x64e.rpf - e5416c0b0000dad4014e0c5e9b878ff9
  • x64f.rpf - 5c6fc965d56ae6d422cd6cbe5a65a3a5
  • x64g.rpf - 1d8a64b337c3e07dffec0f53530cdb8e
  • x64h.rpf - fe657d9282df303b080c3a2f6771c9ea
  • x64i.rpf - bb271d313467465d62c75e208236487b
  • x64j.rpf - 143deee4c7699b9f07ef21d43ae0915b
  • x64k.rpf - da2c88b4ca69c99a86868a9433084a9d
  • x64l.rpf - f4307b005a3e90192f235959621781d1
  • x64m.rpf - a1304d84875747aa7405465d37d3c6fb
  • x64n.rpf - c48a14fe1c301360a16e8b0c5472fd1d
  • x64o.rpf - 6715a4eabbbc8868f15630bf917db49a
  • x64p.rpf - 6ad56befada1db7cccd9cea7834c825b
  • x64q.rpf - ff6d09527d7fdc005d3fa78435e09c8a
  • x64r.rpf - 1465c9da5cc17b68f14915b6c1d815bc
  • x64s.rpf - 2c6e61201eb4f60d5c3c1e9ae6d67a32
  • x64t.rpf - 4c15a54a4c9573d7a0bcfa4689d9d1ed
  • x64u.rpf - 2c9cff0cc5f99ad2218e4c4de39881b7
  • x64v.rpf - db647120263d0282b6f6c555f6112a1c
  • x64w.rpf - 46a4abe50bfc78c30c0173d888cf2c4a
Delete the ones that don't match. Also if it's on steam then use the check for file integrity.
hey me and my friend has been playing gta v on his new acer laptop.
and the game keeps freezing and then crashing when we are at one story mission (offline)
Specs
  • i5-5257U CPU
  • 8 gb ddr3 ram
  • 500gb harddrive
  • intel iris 6100
  • Acer Aspire E5-573
please help us!
https://linustechtips.com/topic/435752-gta-v-help-please/
He's playing on inter grated graphics. What do you expect?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840664
I like, do not know, I'm just puzzled how you got it to run on that in the first place.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840670
Specs
  • i5-5257U CPU
  • 8 gb ddr3 ram
  • 500gb harddrive
  • intel iris 6100
please help us!
If crash occurs for one particular mission means some installation error. Try reinstalling and also turn down all your settings. Update drivers and that's it
| CPU: Intel Core i5 8400 | Motherboard: MSI Z370 PC Pro | CPU Cooler: CM Hyper 212 PLUS | GPU: Zotac GeForce GTX 1070 AMP! Edition | RAM: G.Skill Aegis 16GB DDR4 2400 MHz | PSU: Corsair VS650 | SSD: SanDisk SSD Plus 120GB | HDD: Seagate Barracuda 2TB | Monitor: Dell S2240L | OS: Windows 10 Pro x64 |
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840678
Iris Graphics 6100 isn't total shit.
All interpreted graphics are bad. Even a pathetic 750ti can outperform them.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840691
APUs my friend.
And a 750ti is not pathetic by any stance.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840695
Specs
  • i5-5257U CPU
  • 8 gb ddr3 ram
  • 500gb harddrive
  • intel iris 6100
please help us!
Jesus am not even sure that thing can even run GTA V lol. If he had an AMD APU that would be another story. But Intel doesn't have very good playable onboard graphics. Except for a few flash games and stuff
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840708
"At one story mission"
I'm guessing this is a Heist. Solution:
Don't use firearms while in vehicles, only on foot. (Sometimes it works fines, but you generally don't need to use one, unless the game specifically tell you to shoot)
If you need to use explosives/throwables, use them from within a vehicle, do not use them on foot, they will bug the game once you switch character.
If you absolutely need to use an explosive, but don't have/cannot use, a vehicle, you can use a Rocket launcher.
Seems strange, but that's it.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840731
APUs my friend.
APUs are designed to be "somewhat" good. Even then they are bad because any reasonable GPU would out do it.
750Ti is pathetic. Atleast for gaming, If you want a good gaming experience I suggest no less then a 370 even though it's not much better then a 750Ti.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840756
For some applications (eg. small mitx builds) APUs are very useful, especially in laptops.
And the 750ti can do high settings at 1080p, that's pretty decent for the price, not to mention it's efficiency and compactness.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840770
Specs
  • i5-5257U CPU
  • 8 gb ddr3 ram
  • 500gb harddrive
  • intel iris 6100
please help us!
There's your problem. intel integrated GPUs don't support all the graphical elements of games such as GTA.
For example, GTA might ask the graphics card to draw some smoke in an area. On games of old, smoke is literally a bunch of animated transparent smoke images placed intelligently around the burning object, which any graphics card can easily render. With GTAV it's different. If the integrated graphics doesn't understand the instructions GTA is giving it to draw something such as smoke on the screen, the game will crash.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840812
he plays on the computer fine he has more than 57 fps
and it doesnt crash one mission he crashes at multible missions
Does it give an error? It might be one of the updates he downloaded was corrupted.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840814
You seem like a spoiled brat. Look at it from this person's perspective rather than your perspective.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840843
advice
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840901
Spoiled? I wish.... I have an A6-3650 that can barely push out 30fps in Farming Simulator 2015... I've been saving money for 5 months and have gotten to $400 from mowing more yards then a kid should, doing more chores then a kid should ect ect. I've been working hard trying to get my dream PC.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840909
AMD A6-5200 any better than that A6-3650?
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840917
No, the 3650 is BARELY better.
https://linustechtips.com/topic/435752-gta-v-help-please/#findComment-5840951
