Noctua fans for 10 bucks?????? Time to stock up!
AraSarkisyan
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
Why hopefully it will be for canada too
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
Awww, i though these were the static pressure ones. :(
Double check everything, I am usually wrong.
Awesome thanks so much! I could use a few
Nzxt Phantom 410 - I5 4670k stock - 7950 vapor x @ 1000mhz/1250mhz - Msi Z87 G45 - 8gb Corsair Vengeance pro 1600mhz - TX650 - Benq XL2420t - Blackwidow Ultimate 2013 - Deathadder 2013
It would be a crime to have those for only $10
DAMMIT! I wish they had 140mm or 120mm static pressure ones. I want to replace all the fans in my case. That means 3 x 140mm and 2 x 120mm SP
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
I NEED THESE. vut no money...
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
http://us.ncix.com/products/index.php?sku=27129&manufacture=Noctua&promoid=1082
here,12.99
they do, they are 12.99 for 120mm and 14.99 for 140mm
Lol, don't need rhem already got all noctua fans. :P I even have EXTRA ones :P :)
Do a giveaway
Should I buy a few of these or just buy SP120 & AF140? I understand that these are amazing fans but to be honest I really can't stand the color scheme of Noctua's.
I need good looking fans.
As perfectly good Nactua fans are. I need them in another colour.
Can't wait for the black ones.
The Syndicate
Yeah but those are going to be industrial and spin @ 2000 RPM, Get some Gentle Typhoons.
If only I needed some new fans and if the buy limit was more than one. Already have 4 different fans in my system....
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
Ever heard of undervolting? Or buying the quiet edition fans?
Yeah my comp will look even more wack with just one random noctua fan in it lol
Quiet edition industrial fans will be as loud as normal fans. Industrial fans are made to push as much air as possible. This has already been said by Noctua. It would be smarter to just dye the fans.
thought these were nf-f12s for a second ._. would make it worth the shipping. >_> around £20 for them here.
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
