1080p? Hell yes! Could even do 1440p.
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821829
Get a better PSU lose 16GB of RAM and get a SSD
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821837
three things i can directly say:
- you can NEVER "max out every game"
- at that budget you should really consider an ssd
- Z97 and non-k processor is kind of an odd thing, especially when going i7.
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821842
those specs and youre booting off a WD blue?  get an SSD at least man
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821843
But it's 80+ Gold...
It also happens to be from a series that has extremely good reviews keep the PSU but unless you're planning on streaming or recording drop the RAM down. A 970 can easily beast through 1080p but its really up to you if you want to go with the 980 instead. Oh and... grab an SSD while you're at it...
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821867
For the PSU get a EVGA G1 or GS you've got a G1 which was made by FSP. Companies like EVGA or Corsair take PSUs from companies such as Seasonic and rebrand them.
Don't worry about the SSD. If you are already pushing your budget don't sacrifice performance for a SSD.
16gbs is a good amount also.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821892
The supernova? Not al supernovas are made by the same company. Some are Seasonic. Others are super flower, and some are FSP. The one he picked was made by FSP. You can get much better PSUs that will be much better for the money and much more reliable.
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821902
@STRMfrmXMN
@Aniallation
Please.
Educate this one. He needs it :P
(No offence @Runescapian, but you just need to learn what the gas pedal does before you drive a car.)
EDIT:
Also, do you need the i7? If you are going to do rendering / HEAVY multitasking, go ahead. But, if not, get an i5.
Z97 is made for SLI/Crossfire and Overclocking. But you don't have SLI/Crossfire. Nor do you have an overclockable CPU. What? :P
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5821929
80+ Gold means nothing when it's only good for efficiency and crap at everything else.
http://www.overclock.net/t/1476935/why-you-should-not-buy-an-evga-supernova-nex650g-750g-aka-g1
"Rawr XD"
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5822010
Possibly OP wants a black and white motherboard to suit the color scheme, in which there aren't any B85/H97 boards that have white accents.
"Rawr XD"
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5822021
What would you suggest as a replacement for the G1 he has now?
Cause if I'm correct, it's not really a good unit. Is there anything for around the price that doesn't light his system on fire? :P
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5822045
One of these would be nice http://www.amazon.com/Antec-Current-HCG-520M-BRONZE-Modular/dp/B006TVQTAY/ref=sr_1_1?s=pc&ie=UTF8&qid=1440117073&sr=1-1&keywords=hcg-520m
"Rawr XD"
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5822092
http://linustechtips.com/main/topic/423141-80-plus-efficiency-and-what-it-really-means/
Der ya go
The non 1000W G1 series has awful voltage regulation. The 1000W G1 series is quite good and very much recommended.
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5822952
@STRMfrmXMN
@Aniallation
Please.
EDIT:
1. Tell me your specs, peasant. You're a dick sucking salty little prick.
2. I'm a streamer and do rendering so I will stick with that cpu
3. I plan on crossfiring in the future.
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5835853
1. Tell me your specs, peasant. You're a d### s###### salty little p###.
  1. Not sure if /sarcasm, but there were chances that your system could have killed it's own components, or in extreme cases, lighted fire. I could have let that happen but I called two experts here to help you. Treat people here with a bit of respect
  2. Fair enough.
  3. Then you should be fine with that mobo. Make sure your PSU has enough watts later on, though.
https://linustechtips.com/topic/434386-the-1080p-power-machine/#findComment-5835925
