In games like Minecraft, When I look at the ground in heavily built area my  Graphics Card whines. any way to fix this? If I cant can I return the card?
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
https://linustechtips.com/topic/433580-coil-whine-help/
  • Cap framerate at monitor refresh rate
Heavier game settings (which lowers framerate --> Coil Whine is caused by too much FPS)
RMA
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810883
can you tell us what framerate you have when it whines, in minecraft press f3
LTT's Fastest 9800gt
LTT Forum Beginners Guide
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810886
There isn't really a way to fix it, it depends also if your getting a crazy large FPS that can cause the coil whine to worsen at times. it can also be the combination of that specific PSU and GPU which can make it coil whine.
As for RMA I think some might accept it.
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810887
Just limit the FPS on the game. If it's too loud, make some lame excuse and get it RMAD and get a new replacement.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810891
Oh, 1500FPS.... When i stand still
My Build: Phoenix
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810895
Coil whine is just a natural phenomena. With the technology we have at our disposal now, there's really no way to fix it. They won't take it back unless if it was specifically marketed as 0dB or noiseless or something. You can see if capping your FPS helps.
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810905
Ok thanks guys :D
My Build: Phoenix
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810924
Ok thanks guys :D
Use dxtory to limit btw
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
https://linustechtips.com/topic/433580-coil-whine-help/#findComment-5810976
