Hey, has anybody used this cooler before? The H240X i mean from Swiftech. My CPU goes up to 78*C (1.75v) at 4.0GHz. When no OCed hits 55*C. This is on a hot day (~30*C). Is this normal? Should i perhaps switch to Corsair?
My system is in my sig.
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
https://linustechtips.com/topic/428221-is-there-something-wrong-with-my-cooler/
1.75V are you sure that's correct?
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
Is that whilst stress testing? If so, that's fine.
More more importantly, did you enter your voltage properly? 1.75v is way too high :/
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
Wait... Damn ... I read wrong. 1.175V
any voltage above 1.4v on the cpu is for ln2 / dice/ sub zero cooling man .... your gona kill your cpu at those voltages
Please quote me or tag me if your trying to talk to me , I might see it through all my other notifications ^_^
the current list of dead cards is as follows 2 evga gtx 980ti acx 2.0 , 1 evga gtx 980 acx 2.0 1600mhz core 2100mhz ram golden chip card ... failed hardcore , 1 290x that caught fire , 1 hd 7950 .
may you all rest in peaces in the giant pc in the sky
Sorry... Refresh
Turn the voltage down!
EDIT: nvm 1.175 :P
Alright... Sorry i hate writing on an Pad...
Anyways 1.175v i heard it's good from people from overclok.net... Im just curious about the cooler... Wasnt so high in any of the benchmarks at all...
Most benchmarks don't specify much, what stress testing are you using and is your voltage on manual?
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
Hope you aren't running P95.
Mine will hit the same temp but at 4.4GHz 1.27v with AIDA 64.
Not Prime95. I used AIDA64 and the Asus benchmark... I can't get it further than 4.2GHz cuz it crosses 80*C. I am going to have to maybe do a custom loop if i want to add a GPU to my loop?
I am looking to get GP100 Big Daddy Pascal to LC it.
The pump of the H240-X is powerful enough to drive more components. Just add an extra 240 or 360 rad(or 280, 420mm) whatever size that fits your case.
Have you tried to re-do the CPU block mounting? Could be a slight bad contact/gas pocket of thermal paste/uneven pressure, that leads to bad temp. Also, do you mount the rad as intake or exhaust? A very hot GPU can dump load of heat in to the case. Then you're using the hot air inside the case to cool the CPU if you configure the rad as exhaust. Or if you've a case with restrictive air flow, or a very dense intake filter. That could hamper the cooling too.
One more point. I suppose you're using the stock Helix fans come with the cooler. The fans are ok but not great. Better fans will help lower the temp by 2-4*C.
The pump of the H240-X is powerful enough to drive more components. Just add an extra 240 or 360(or 280, 420mm) whatever size that fits your case.
Well my case in in my sig - Vengeance C70 from Corsair. I have fans everywhere. 2 front SP fans, 2 side AF fans, the rad is an intake with stock Swiftech Helix fans. I only have my rear fan exhaust and my PSU exhaust. My GPU does not go higher than 65*C no matter how far it is overlocked. So i can use 2 120mm rads for rear and bottom.
I did the cross thing with the Thermal compound. I will re-apply it. See if that works.
Or maybe, is the pins? I have my pump, on red, and 2 fans on blacks on the fan splitter they provided with the cooler, and that is plugged in the cpu fan pins on the MB.
Pump speed doesn't do much for CPU temp above a certain level. For only one rad and a CPU block. Anything above 2,000rpm for the pump doesn't provide improvement(I think) but making noise. I'd rather plug one of the fan to the red-location and manage your fan speed through Asus BIOS. The stock fan has a max speed of 1,800rpm. Set the fan speed to 1,200-1,300rpm max under load, if you prefer a quiet rig. The pump will have provide sufficient flow. See if this makes the CPU temp cooler than your old set up.
