Safe to Insert GPU without Case?
Solved by Raffy98,
Even though the graphics card will be held in by the PCIE slot alone and the water cooler would be hanging over the side of the motherboard since neither of them have a place to be mounted?
I think as long as there is not much pressure in the graphics card to like... fall over and disconnect from the PCI-E slot and for the motherboard to fall off the desk (or what you have
) you should be safe.
I saw Linus doing this on few Episodes of Ncix Tech Tips. ![]()
