I'm looking for a CNC machine to cut Aluminum panels modding cases and creating my own. Any recommendations?
Budget?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/424300-personal-cnc-machine/#findComment-5696171
Damn got excited thinking you meant Command and Conquer :(
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/424300-personal-cnc-machine/#findComment-5696174
The large version of the X-Carve machine, I'm not sure what size of CNC your looking for.
https://www.inventables.com/technologies/x-carve
https://linustechtips.com/topic/424300-personal-cnc-machine/#findComment-5696200
I tweeted them and asked if it could cut aluminum but no answer. Can it?
It can you just have to take your time on these DIY types.
In their FAQ:
What materials can I carve on the machine?
Woods (both hard and soft), various plastics and non-ferrous metals like aluminum, copper and brass.
The Shapeoko 3 and C-Beam OX's are a bit more rigid than the X-Carves though.
https://linustechtips.com/topic/424300-personal-cnc-machine/#findComment-5696269
Yes it does soft material and metals like aluminum, as Drrizz just said.
One really good tip I picked up if your just doing long rip cuts or straight cuts of stock or materials a table saw with just a regular carbide wood blade works amazingly well, there are oils or waxes that can help also, not to mention the proper aluminium cutting blades which are the same thing but less rake on the teeth and etc..
https://linustechtips.com/topic/424300-personal-cnc-machine/#findComment-5696278
In their FAQ:
Thanks man!
https://linustechtips.com/topic/424300-personal-cnc-machine/#findComment-5696283
That would be c&c not cnc.
But people also referred to it as "C 'n' C" like phonetically
My Rigs:
Case:
Case:
https://linustechtips.com/topic/424300-personal-cnc-machine/#findComment-5696478
