I'm trying to find the bet bang for the buck GPU. I've been keeping my eye on these two ( 1 - 2 ) but I know there is a way better one out there. My budget for the GPU is $230
EDIT: Fixed Links
 R9 290/x used if you can get one for that?
Sig under construction.
EDIT: Fixed Links
out of those two, 280x.
but you can buy a used 290/290x, 970 for around that price or even less.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
if you are willing to go over budget this is a good deal
http://www.ebay.com/itm/EVGA-GeForce-GTX-780-3GB-Dual-Classified-ACX-Video-Card-/111733505755?hash=item1a03d5fedb
otherwise getting a used r9 290 / gtx 770 would work too
Vapor-X is slightly more cooler and silent over the Tri-X but if you think it is worth the $20 extra it is your call. There will be very small or if any performance difference between them.
EDIT:
wait the Tri-X is 270x and the Vapor-X is 280x
get the  280x Vapor-X then.
Or if you're into the used market theres a good chance at getting a 780 for the same price, but thats up to you and if you look hard enough.
look at 280's if you want cheap that beats the 270x
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
