Vegas won't open...
Solved by Arti,
You don't need a torent, Just dl a trial, and there is 1 file you can add, oops I have said too much....
I installed Premier CS6 and when it loads it also gets stuck on "Loading FileOutputAvi" so i solved by uninstalling all of my codecs and installed new codecs for windows 8 and got it to work. Even vegas started to work...
After all it was just a problem with the AVI codec and premiere pointed that out to me XD.
But i guess i will continue to use Premier CS6 cuz i edited one video in it and when dealing with compressed MP4 files it's soooo much smoother than vegas and has much better effects and transitions ;D.
Thanks for your help.
