USB Hub disadvantages?
Solved by SuperOwnJK,
I think latency is a slight issue with USB Hubs. Also some USB 2.0 devices plugged into a 3.0 port can cause issues. If I was you I'd plug keyboard(1), mouse(2), headset(3), Graphic tablet(4), External hard drive 2.0(5), USB Hub(6). Then Blu Ray and External Hard Drive 3.0 into the USB 3 ports, then everything else in usb hub.
EDIT: You can charge phones from USB Hub but it can charge slower. I'd get a powered USB Hub that you have to plug into the wall to supplement power.
