Fan that will fit in my case?
Solved by tomas710,
The one I linked; I looked at the reviews... a good number of them failed within months.... Isn't that normally a bad sign?
Honestly, 120mm AIOs are not worth it, get this cooler or something similar, i know this particular one outperforms the hyper 212 evo and will fit in your case
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103204
Featured Topics
4
13
2
JFRStudent ·
Posted in Photography and Videography1
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
