Hey guys, I'm relatively new here at this forum.
I'm looking for a budget gaming system for around £250 - £300 excluding OS
So far I've come across a G3258 and Z97 motherboard and 8gb DDR3 ram. I'm not sure if this is the best combination
I was thinking of also adding a 750ti GPU
I'm currently looking at www.scan.co.uk as my seller.
But I'm open to any suggestions.
Any tips?
Thanks
https://linustechtips.com/topic/419912-need-budget-gaming-system-help/
Sorry to break it to you man, but 300 euros is definitely cheaping out on a computer. Especially if it's going to run games on it. In this case, I would mainly focus on your cpu and gpu. Not sure to what extent you care about looks but if you are looking for a sexy, cheap, and durable case i would go with the nzxt s340. I just built my first pc too and this case is amazing and high quality for the price. And but yeah, if you are going with that price it's definitely a good idea to go on other sites to look around for good prices. In the end, I'm no expert on computers since I just built my first computer for $1,000 USD. In my case, I was originally going to go with a $750 USD build with AMD specs but in the end I just ended up saving my money and doing more research and in the end I'm super glad I did that because right now im currently on an amazing pc that I can feel proud of and show my family and stuff. Well, sorry for not answering the question too much but just look around pcpartpicker to see where cheap prices are available.
thats not bad, im not a fan of the 750TI because i have one now and it has a bunch of problems but that seems to be literaly just my card so maby dont get the MSI OC 750TI, thats my only advice oherwise it looks quite nice, get a aftermarket cooler and OC that CPU to shit and you have something thats not that bad :D
Builds:
Eh. The list looks good if you are only going to play stuff like csgo and tf2. Other than that, I would strongly recommend you to upgrade to a quad core cpu. Doesn't matter which one, but most games nowadays can only run decently with a quad core cpu. Other than that, the rest looks good if you are trying to stay on a strict budget.
Any tips?
Thanks
Best i could do and this is not considering and color theme or personal preferences, just cost and performance.
  1. CPU
  2. GPU
  3. MOBO
  4. PSU
  5. RAM
  6. Case
this totals to £312 and it doesn't have a mouse, keyboard, speakers and monitor but play around with it and see what you come up with. you could also look for H97 MOBOs rather than z97, it would be cheaper.
EDIT: look in the warehouse deals section to see if you find good deals too.
Edited by Leonard
A water-cooled mid-tier gaming PC.
PCPartPicker part list: http://uk.pcpartpicker.com/p/Cg73Jx
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  (£85.01 @ Ebuyer)
Motherboard: Asus H81-GAMER ATX LGA1150 Motherboard  (£66.48 @ Amazon UK)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory  (£34.71 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£39.00 @ Amazon UK)
Video Card: EVGA GeForce GTX 750 Ti 2GB FTW ACX Video Card  (£103.00 @ Ebuyer)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  (£27.95 @ Amazon UK)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£39.99 @ Amazon UK)
Total: £396.14
Generated by PCPartPicker 2015-07-31 14:52 BST+0100
This is over by about 100 pounds but I'm pretty sure you could save up 100 pounds in no time
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
http://uk.pcpartpicker.com/p/vKF3Jx
Something like this?
I would recomend looking at CEX/Gumtree maybe for a used GPU if you can fit it in your budget.
Do I seriously need a 500w power supply for that set up? can't I get away with a 430 xfx?
Total: £396.14
Thanks, that looks reasonable.
Does this i3 have room for an OC?
Some people are saying that I would need a quad core for games such as GTA V?
Also is there a heck of a difference between a g3258 at 4.6ghz vs this i3?
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  (£58.76 @ Scan.co.uk)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1600 Memory  (£34.79 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£32.40 @ Aria PC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  (£95.99 @ Amazon UK)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£28.09 @ Amazon UK)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£38.48 @ Novatech)
Total: £373.52
Generated by PCPartPicker 2015-07-31 17:18 BST+0100
or, with an r7 370:
Video Card: Gigabyte Radeon R7 370 2GB WINDFORCE 2X Video Card  (£122.50 @ Aria PC)
Total: £400.03
Generated by PCPartPicker 2015-07-31 17:19 BST+0100
BigDay
No OC but stronger single core performance. OC g3258 probably not near as good as the i3. Not sure about GTA V though
You can't even overclock an I3...
Are you gonna upgrade it later? No? Get Athlon X4 860K :P
Are you gonna upgrade? Yes? Then go for Pentium and get best 1150 k CPU you find later!
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
What he said.
She... :P
Apologizes. What she said.
*yays* :)
  1. CPU
  2. GPU
  3. MOBO
  4. PSU
  5. RAM
  6. Case
Whats the difference between a H97 and Z97
Z97 has more in-depth features than h97, one of which is way better OCing for the CPU, RAM and chipset(no one really uses this nor does it give any really world boost in performance but you can do it) Since you are buying an OCable CPU it would be with to get all the performance you can out of it, hence the z97 MOBO.
you can overclock with z97 while you cannot with h97
You can OC with a H97 but just not as in-depth or as high as with a z97.
