Using aftermarket coolers for non-oc cpu
louis21ong
Does it make sense to have an aftermarket cooler on my i3-4170? Ambient temps in my room is about 38 degrees and my cpu at load gets to about 68-70deg. I'm planning to get a 2nd hand Hyper 212 Evo for around ~$20 from my friend who switched to water cooling. Oh and one more thing, I'm planning to get a 4670k when I get money for it. Any comments would be appreciated. Thank you!
I don't think your CPU should be that warm..... i3's do not run hot. Sure the heatsink is seated properly? The thermal paste isn't messed up?
But that being said, if you do plan on getting a 4670k (assuming you have a Z87 or 97 board so you can actually overclock it...) the hyper 212 idea aint bad. You will need better cooling to OC the i5 once you get it. And 20 bucks for a 212 is a great deal!
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
If you want to reduce air temps for a locked CPU, a cheap cooler such as the hyper 212 Evo will do the trick, dont need to invest hundreds of dollars for a water cooler.
The hyper 212 Evo will also come in handy for your 4670k, though I would recommend getting the 4690k instead as it had a better heat spreader over the 4670k, and that will help to reduce temperatures.
Quote me if you want me to see your message. Like my post if it helped. Click "Show More" to see things that I use.
Desktop (2014): CPU: Intel Core i5 4690k @ 3.50GHz | GPU: MSi GTX 970 Gaming 4G | Motherboard: MSi Z97 Gaming 5 | RAM: 2x4GB G.Skill RipJaws X 1600MHz + 2x4GB HyperX Black 1600MHz | SSD: Samsung 750 Evo 120GB | HDD: WD Black 1TB | Cooler: Cooler Master Hyper 212x | PSU: Corsair VS650 | Case: Cooler Master Elite 431 Plus | OS: Windows 10 Home
Laptop (2017): Model: Asus UX310U
Peripherals: Monitor: Samsung S24D300 OC@75Hz + Viewsonic XG2401 (144Hz) | Mouse: Logitech G305 | Keyboard: Razer Blackwidow Chroma V2 | Headset: HyperX Cloud Core | Speakers: Logitech Z333 | Additional: Logitech G29
Mobiles: Samsung Pixon (2010-2012) | Samsung Galaxy Ace (2012-2013) | Samsung Galaxy S3 (2013-2016) | Samsung Note 4 (2015)(Lost) | Samsung Galaxy S7 (2016-2019) | Samsung Galaxy S10 (2019 - Current) | Additional: ASUS Zenwatch 2 (2016)
I don't live in the US by the way. I live in the Philippines where heat is really a problem. And yes, I will get a good z97 board along with the 4690k.
Yeah I was talking about the 4690k. I realized they didn't sell 4670k's here in the Ph anymore. Thank you!
Look at ambient first and them CPU temps. The temps are normal with that high ambient.
@louis21ong, 212 Evo for $20 is really nice pick and while it doesn't help that much with your temps, it will be much quieter than stock cooler. And will be much better choice for 4670K.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Well if you did you could get a really quiet system.
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
Sounds good to me, you won't see a benefit in the i3 but it's the same mounting as the i5, in which you will see a tremendous benefit, specially if you plan on doing some overclocking, so, i would buy it, specially if you are buying it from a friend since it takes the risk off of buying 2nd hand and for heatsinks it doesn't really matter.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
